88 YJ Clutch problems - JeepForum.com
post #1 of 4 Old 09-16-2012, 06:39 PM Thread Starter
bbhuey2000
I have a 88 yj. Just put a 75 4.2 258 motor in it and working on the clutch now. The clutch will shift fine for about a mile then it is next to impossible to put it in any gear. i turned the motor off and pumped the peddal and then it worked again for about a mile. I got it home and bled the clutch only for it to do the same thing again. I have replaced the master cylinder and the slave cylinder and put fresh dot3 fluid in it. same issue i cant get it to go into any gear. no leaks on the master or slave lines. I need any help i can get. im gonna try to get the tool to do a reverse bled in the next few days.
bbhuey2000 is offline
post #2 of 4 Old 09-16-2012, 06:42 PM
gotwood
They are a pita to bleed.
gotwood is offline
post #3 of 4 Old 09-17-2012, 07:32 PM
Jimmy3841
When I did mine, I had someone help me and push the pedal real slow while I had the screw open. I would close it of course when he was just about at the end of the stroke. When I was done I had to pump a bit if it sat over night but it worked itself out over a couple of days. Also I've heard of people using an old style oil can, the type with the thumb pump, and using that to push the oil up from the bottom. Just my experience.
Jimmy3841 is offline
post #4 of 4 Old 09-17-2012, 10:05 PM
jokerchief462
88 has an internal slave so you can really check it closely. The way it attaches is not the most reliable. If it is leaking you will see it on the what is an inspection plate or dust cover for that area of what is in the bellhousing. On the I6s you can't remove it so just look for leaks. If it is leaking time to pull it aapart. If not the slave look in the cab where the clutch pedal actuator pushes the master piston in it will leak down the firewall. Good luck.
jokerchief462 is offline
clutch problems nickaldrich YJ Wrangler Technical Forum 4 10-13-2010 12:22 PM
Clutch problems Hurley91 YJ Wrangler Technical Forum 6 12-14-2009 09:31 PM
clutch problems "double clutch shifting" propkillr YJ Wrangler Technical Forum 4 07-11-2009 12:08 PM
great! More AX5 Clutch problems!!!!! hooray for internal clutch slave cylinders! Big-n-Broke-YJ YJ Wrangler Technical Forum 6 08-19-2008 02:14 PM
TJ Clutch Problems Tallpaul TJ Wrangler Technical Forum 33 08-09-2008 02:13 PM
