'88 YJ clutch master cylinder replacement - JeepForum.com
post #1 of 1 Old 05-05-2008, 10:42 AM Thread Starter
BlackSheep92
OK, before I make a complete mess, lose parts and create a ton of frustration I could do without I'm again asking for sanity saving advice.
I read a post, with pics, of a similar problem in which a YJ's (89?) clutch was leaking fluid through the firewall. I have the same problem, a dry reservoir and fluid leaking down the firewall.
I decided to replace the master cylinder (or, at least at this point, purchase it)
Now before I go unbolting things and unhooking lines, what needs to be done to complete this? I've heard horror stories of something not being bled properly, or prepped properly and catastrophic events taking place and winding up in worse shape then when you started.
Anyone offer any help?
"Courage is not the absence of fear. It is the willingness to move forth despite it's presence"
BlackSheep92 is offline
Clutch master cylinder replacement Mean Max YJ Wrangler Technical Forum 107 09-26-2014 04:06 PM
Clutch Master Cylinder Replacement biasdesign YJ Wrangler Technical Forum 5 07-28-2009 07:27 AM
Clutch Slave and Master Cylinder replacement jonner YJ Wrangler Technical Forum 13 08-03-2006 10:58 PM
Need you thoughts on Clutch Master Cylinder replacement Johnny World YJ Wrangler Technical Forum 7 05-19-2006 06:38 PM
clutch master cylinder replacement ? freakydiver YJ Wrangler Technical Forum 6 02-20-2006 05:30 PM
