88 YJ Clutch Drag - No Hydraulics? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 88 YJ Clutch Drag - No Hydraulics?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE Shipping Sale!FS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 06-27-2015, 10:05 AM   #1
MattGinOK
Hi, FNG here.
Just purchased '88 YJ. BA10-5, 4.2L, 4x4 (231-AMC). Had dragging clutch, really bad. Almost like no pedal assist at all. In looking at trans, going to replace w/AX15, found at least 1 thing. See picture of side transmission. Looks like something is terribly wrong, but this is my first shot at diagnosis. I think the clutch hyd. is not working at all.
What do I need to do to get it working again, parts wise? I found the write up on bleeding.
thanks
MattGinOK
MattGinOK is offline   Reply With Quote Quick reply to this message
Unread 06-27-2015, 10:44 AM   #2
Beachcruiser
1987 YJ Wrangler
You can try bleeding it from that bleed screw in you pics (the end sticking out), but chances are your slave and/or master cylinder are going out. Check clutch fluid level first, of course.
If that doesn't help...you might as well do the AX-15 swap. because you have to pull the trans for the slave cylinder anyway.
probably out breaking stuff.
Beachcruiser is offline   Reply With Quote Quick reply to this message
Unread 06-28-2015, 09:16 AM   #3
MattGinOK
Figured as much.
got a line on a '02 wrangler NV3550 transmission w/Clutch, flywheel (ask $700). Need to see if bell housing comes with it. So, I guess it's go for AX15 or NV3550?
This should probably should be another thread.
thx
MattGinOK
Unread 07-02-2015, 08:50 AM   #4
MattGinOK
maybe not need trans
the bleeder was so hard to break, I needed vise grips. That being said, I bled it some and lo and behold I've now got some clutch. Am going to bleed again and ALSO put a nut on the top of the torque arm. That nut BTW is 3/8-24.
thanks all.
Unread 07-02-2015, 10:36 AM   #5
Opihi59
from here it gets rough
Opihi59's Avatar
Nothing wrong with driving it a bit to see how it does after you get it fully bled. But very good idea to replace your tranny with AX 15 or NV3550. The 3550 will definitely be external slave so that's a real bonus, or at least if you go AX15 make sure yours is 94 or newer and it will be external slave as well.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock http://kamfamily.wordpress.com/2009/...waiian-limpet/
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is online now   Reply With Quote Quick reply to this message
Unread 07-03-2015, 08:42 AM   #6
MattGinOK
Thanks Opihi59
A little new info every day helps in the long run. If the BA10 works ok when I'm done, I'll still keep a lookout for an AX15 or NV3550, it just won't have the immediacy.
Thanks
Matt.
slave cylinder
