'88 YJ 5.3L Vortec Build Thread - Page 8 - JeepForum.com
post #106 of 143 Old 03-05-2010, 06:36 PM Thread Starter
fatwreck
So, I got mine running tonight....with throttle this time.
It turns out that I had a broken wire right at connector for the pedal...not the throttle body like the TSB said. In the process of trying to diagnose it all....I did some continuity tests and came across it. I fixed the wire and plugged it in...and it worked like it was supposed to. That was causing some serious stress in my world.
Time to move on to gauges.
fatwreck is offline
post #107 of 143 Old 03-14-2010, 08:11 PM Thread Starter
fatwreck
Video of it running. Note...it's throwing 2 codes regarding one of my oxygen sensors. I think that is why it is running rough and smoking some. Any insight?
YouTube - 1988 YJ with a 5.3L Vortec engine
fatwreck is offline
post #108 of 143 Old 03-15-2010, 08:51 AM
1 ton yj
1 ton yj's Avatar
first before anything you need to figure out why it's throwing a code and fix it. It'll never ever ever run right as long as that light is on.
Second, your computer has been unplugged for a while. It's normal to run rough on first startup after something like this. The computer has memory so it needs to run rough for 10 or 15 minutes or however long it takes to learn the idle mixture and iac position.
Who did you tune and what exactly did they do to it?
1 ton yj is offline
post #109 of 143 Old 03-15-2010, 08:58 AM Thread Starter
fatwreck
That was not the first start up. I've ran it for more than 15 minutes at this point. I'll get the O2 sensor figured out and go from there.
wait4meperformance did the tune and I really don't know what they did to it. I have a friend with hptuners and we took a look at some of the items, but neither of us really knew what to look for.
fatwreck is offline
post #110 of 143 Old 03-15-2010, 10:05 AM
73Dart
Mine did this same thing. It would not idle and the IAC motor would throttle it up and down and then it would die. After a few min it smoothed out like it was trying to recalibrate itself. The van that the motor came out of had sat for about 3 years with a dead battery.
89 YJ with a 5.2l V8, 5 Speed ax-15, RC aals giving me 1.5" of lift plus 1" lift shackles giving me a total of 2.5" of lift, 31x10.5x15 A/T tires, no carpet, rinolined tub, Family style roll bar.
73Dart is offline
post #111 of 143 Old 03-18-2010, 05:34 AM Thread Starter
fatwreck
I ordered up new male/female O2 sensor connectors. I should be able to put the correct ends on now and eliminate any splices. I'm hoping this will solve my problem. If not, it will at least help me narrow it down.
I spent some time last night wiring up my gauges. This part of it is almost done, but I still need to install the senders for the water temp, oil pressure, and trans temp.
fatwreck is offline
post #112 of 143 Old 03-23-2010, 06:01 AM Thread Starter
fatwreck
Ok, so I spent some time last night to replace the lame splice job I had done on my harness to switch the O2 sensor end from male to female. I made sure to tin the wires before I crimped them into the delphi O2 sensor connector. I then soldered them in afterwards to guarantee I had a good connection. I'm happy with how that turned out. I then put the correct female end on the O2 sensor. This gave me the ability to swap the sensors from the driver side to the passenger side as another means of diagnosis.
I started off by clearing the clodes and leaving the sensors where they were. I fired it up and got the same error (P0155 HO2S Heater Performance Bank 2 Sensor 1) for the passenger side O2 sensor. I then swapped the O2 sensors from side to side and cleared the codes. I fired it up and this time I got a different error (P0135 HO2S Heater Performance Bank 1 Sensor 1) for the driver side. That seems to indicate that I have a bad O2 sensor, even though it is brand new. I'll get a new one shortly.
It's definitely running super rich. Both of the O2 sensors had a light black coating on them and I'm throwing black smoke out of the exhaust.
In addition to working on the O2 sensors, I also spent some time last night wrapping up the gauges. I got the oil cooler fitting tapped for my oil pressure sender and I got the center section of the dash installed. All of the gauges appear to be working, except for my water temp since I don't have my adaptor/sender yet from Auto Meter.
fatwreck is offline
post #113 of 143 Old 03-23-2010, 06:11 AM
skot0123
Sounds like you are on the right track.
I may have missed it but where did you get the gauge dash panel from?
skot0123 is offline
post #114 of 143 Old 03-23-2010, 06:16 AM Thread Starter
fatwreck
I got from the same guy on pirate that I got the rest of my gauges from: Superduty HQ - Home of SDHQ Offroad Racing
It's an Auto Meter part: 15218.
fatwreck is offline
post #115 of 143 Old 04-06-2010, 05:49 AM Thread Starter
fatwreck
I registered the jeep last week and drove it to the gas station a couple of times. It registered two new codes: PO172 and PO175. It's running rich on both sides of the engine.
DTC P0172 Fuel Trim System Rich Bank 1
That link and another one seem to indicate that the MAF could be bad or that I have a vacuum leak. I did buy a used MAF sensor off of one of the forums....and the only thing that I have done with vacuum is hook up my brake booster off the back of the intake. Are there other areas that need to be plugged?
fatwreck is offline
post #116 of 143 Old 04-06-2010, 07:43 AM
jaywiz1977
Are you sure that the o2 wiring that you "had to move" from the trans harness was for the right o2 sensor and not the one right b4 the converter?I had mine in the wrong locations and I ended up with the same code and a rich running vortek,get a pin out for your pcm and run a continunity check to the pcm plugs.Thats how i figured out my slip up,i then found another o2 set of wires and got them all worked into the right config and bang no more codes!
There are alot of different people in the world out of all of them,it's the normal ones that scare me the most!
jaywiz1977 is offline
post #117 of 143 Old 04-06-2010, 08:55 PM
ktwnxj
1987 XJ Cherokee
great build thread, just registered, i want to see how it winds up as a finished project!
ktwnxj is offline
post #118 of 143 Old 04-07-2010, 07:20 PM
rb440mike
One thing that comes to mind is the vacuum line going to the fuel pressure regulator. If this is disconnected or damaged, the fuel pressure will not decrease when your at idle with high vacuum causing the rich condition. Do you have the tools to check fuel pressure? Another possibility is a problem with your return line, make sure you can blow through it without any restriction. You may want to plug the hose to the brake booster as it could have a large internal leak reducing the vacuum. Keep us posted. I'm doing the same swap and will be curious if the stock radiator is going to work.
rb440mike is offline
post #119 of 143 Old 04-22-2010, 06:45 PM
lilgreenjeepyj
Any pictures/info on how you hooked into the vacuum port on the intake manifold?
lilgreenjeepyj is offline
post #120 of 143 Old 04-23-2010, 05:24 AM
green89yj
It definitely sounds like you may have the wrong O2 sensors or have them switched around. I was lucky enough to be able to pull my 4.0 and label everything as well as I only have one upstream and one down stream.
Herc.Custom Green paint. RC 4". 5 Goodyear 33X12.5 MT/R w/Kev. Cragar V5's. Corbeau Moab seats. Optima Yellow.XRC8 Comp Winch. XJ 4.0/AX15
WTT: 4" springs for 6"
WTS: 4.2 parts. Fuel lines, pump, block, head, accessories, just ask
green89yj is offline
New Build Thread wanabejeeper YJ Wrangler Technical Forum 70 12-17-2012 12:48 PM
My YJ Build Thread obsessedjeeper YJ Wrangler Technical Forum 14 07-01-2010 01:22 AM
88 YJ Build Thread RebuildRookie YJ Wrangler Technical Forum 59 04-05-2010 07:27 AM
YJ Build Thread??? YJ_eep1189 YJ Wrangler Technical Forum 7 12-17-2009 05:19 AM
Vortec Or No Vortec...That Is The Question ShowMeJeep YJ Wrangler Technical Forum 16 02-28-2007 08:32 PM
