'88 YJ 5.3L Vortec Build Thread - Page 10 - JeepForum.com
post #136 of 143 Old 07-26-2010, 08:25 PM
rixxs00
Great stuff I am doing the same thing, Are you using your stock drive shafts? today I also mounted my Lokar shifter to my 4L60E
rixxs00 is offline
post #137 of 143 Old 07-27-2010, 05:25 AM Thread Starter
fatwreck
I bought new driveshafts f/r. I initially had the engine placed farther forward than it is now...and I think I could have reused my front driveshaft, but after I moved it back about 4"...I had to get a new one.
fatwreck is offline
post #138 of 143 Old 07-27-2010, 07:25 AM
rixxs00
I am going to try and use my old drive shafts I am going to dry fit every thing a just my motor and fit my drive shafts I hope it works..
rixxs00 is offline
post #139 of 143 Old 07-28-2010, 04:23 PM
1 ton yj
1 ton yj's Avatar
not recommended
1 ton yj is offline
post #140 of 143 Old 07-28-2010, 07:02 PM
rixxs00
That is what am am being told, I guess I will have some made hope they don't cost too much already spent over 3K
rixxs00 is offline
post #141 of 143 Old 07-28-2010, 07:15 PM
1 ton yj
1 ton yj's Avatar
Why have them made, just shorten or lengthen the ones you have yourself.
1 ton yj is offline
post #142 of 143 Old 07-28-2010, 07:47 PM
Jeeper_YJ
You have $3k into your build?
'97 Cherokee, 99+ intake, 62mm TB, 703 injectors (new), k&n intake, Hypertech III, 180* stat (1/8" drilled hole), 2.5" manifold 2 tail pipe (Hooker Maxflow & hi flow cat), Perf header, 4.5" zone lift, 32" GY Dura Trac, Rear head rests. Comp cam "231" & Perf head (LS1 BIG valves 2.02/1.62). 3 row alum radiator.
Jeeper_YJ is offline
post #143 of 143 Old 02-25-2013, 02:49 PM
indirocz28
Awesome build man! Too bad you sold it!
Could have been a good YJ Of the month.
indirocz28 is offline
New Build Thread wanabejeeper YJ Wrangler Technical Forum 70 12-17-2012 12:48 PM
My YJ Build Thread obsessedjeeper YJ Wrangler Technical Forum 14 07-01-2010 01:22 AM
88 YJ Build Thread RebuildRookie YJ Wrangler Technical Forum 59 04-05-2010 07:27 AM
YJ Build Thread??? YJ_eep1189 YJ Wrangler Technical Forum 7 12-17-2009 05:19 AM
Vortec Or No Vortec...That Is The Question ShowMeJeep YJ Wrangler Technical Forum 16 02-28-2007 08:32 PM
