88 wrangler wont start - Page 2 - JeepForum.com
post #16 of 31 Old 04-23-2010, 07:50 PM
shatteredsoul
Coil then? or burnt plug wire from coil to distributor? I think the standard is 1000 ohms per foot of plug wire which would tell you if the wires are bad.
shatteredsoul is offline
post #17 of 31 Old 04-23-2010, 07:51 PM
Old4X
1990 CJ7
Sounds like your Ignition Control Module isn't getting power.
IIRC, on the 2 wire connector to the ICM (under the washer bottle) the red wire is your 12V input in the run position of your ignition switch. The other wire is hot in the start position.
This is what powers up your module and provides power to the coil.
Do a google for "88 jeep ignition and starter wiring", there are schematics available free. You have to have the wiring diagrams to properly troubleshoot this, else you will be replacing parts that aren't bad, and may never find the problem if it is a bad connector or broken wire.
A multimeter helps, but you can do about all of this with just a test light.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #18 of 31 Old 04-23-2010, 07:59 PM
Old4X
1990 CJ7
Just read your latest posts. If coil has power, the module has power. Check the other connector on the ICM, make sure it is clean and full of dielectric grease. Make sure the pins are all making good contact. Do the same for the 3 wire connector coming off the distributor.
Old4X is offline
post #19 of 31 Old 04-23-2010, 09:15 PM
photoboy74
I had a similar problem after doing the TFI upgrade on my 88. For the longest time, I thought it was something major like the ICM, but it turned out to be the two wire connector on the coil. I purchased a new connector at the auto parts store when getting a new coil, and there was too much plastic on it to properly slide over the terminals of the coil for proper contact. The end result was intermittent failure when starting until it completely stopped working.
So, I suggest if you have power coming for the wire to the coil, pull the wires from the plastic connector and slide them directly on the terminals. If it starts up, there is the culprit (especially when you said you tried another coil). Then you just need to shave away some plastic for them to fit better.
photoboy74 is offline
post #20 of 31 Old 04-24-2010, 01:03 PM
monkeyhouse
Originally Posted by 88yj View Post
There is power to the coil but nothing after the coil.I check with a different coil and i got the same thing power to not after
cut the wires that go to the coil connector, and attach them directly to coil tabs(make sure they are clean).
Get a wiring diagram
I found this on a thread after doing a search, might be something to check as well, but you really need a diagram so you can stop guessing and troubleshoot correctly. Here's the post:
I just checked the diagram for an 88 jeep wrangler w/4.2 and it does have a pick up coil in the distributor. there should be three wires comming out of the dist. follow them to the connector unplug it. if the connector is all crappy you may have found the problem, if not carefully put the voltmeter leads in the conector (one lead in the orange wire hole and one in the violet it doesn't matter which). DON'T woller out the hole so the leads will stay on their own. set the voltmeter on AC voltage and crank the engine. if it makes voltage move on to something else if it doesn't replace it.
don't for get to check power and ground to the modules. be careful module cant handle much amperage. analog voltmeter not a good idea, test light not a whole lot better, digital voltmeters don't allow much curent to flow through them and will prodent the module so use them if posible.
Found that info here:
88 4.2L ignition module test - Pirate4x4.Com Bulletin Board
I'll edit my post if I find you a diagram
Not a diagram, but a lil help:
http://www.bulldogsecurity.com/bdnew...ngdiagrams.asp
Okay, I think there is a diagram in this pdf that will help. It includes years 87-94, the year is at the bottom of each page.
http://iwantajeep.s3.amazonaws.com/w...ams-copy-1.pdf
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #21 of 31 Old 04-25-2010, 04:41 PM Thread Starter
88yj
I just checked i got spark it gets gas the spark plugs look good what else could it be still wont start.
88yj is offline
post #22 of 31 Old 04-25-2010, 05:18 PM Thread Starter
88yj
Ok i just went out and sprayed starting fluid in the carb and it started right up so i shut it off 3-4 times and it started right back up.I let it run for 10 min and then it just died.Now im back to not getting any spark except when u first start cranking it sparks once and when i stop cranking it sparks once is that the ignition control module
88yj is offline
post #23 of 31 Old 04-25-2010, 05:34 PM
dtn8tr
If it started up with the starting fluid then you are getting spark! The issue sounds more like a fuel delivery issue. Get a Haynes or chilton manual and it tells to how to do a volume check on your fuel pump.
1997 TJ, 5" IRO front with 4.5" HD IRO WJ rear, 35x12.5x15 Mickey Thompson MTZ, JKS disconnects
dtn8tr is offline
post #24 of 31 Old 04-25-2010, 05:51 PM Thread Starter
88yj
It gets fuel it just went back to not getting spark again
88yj is offline
post #25 of 31 Old 04-25-2010, 06:44 PM
monkeyhouse
will it start every time you use starter fluid? It is sounding like a fuel delivery issue if it started on starter fluid, but if it ran for 10 minutes, that doesn't explain much, because the starter fluid should burn up in a few seconds. I'm no expert here, but maybe this is a mixture or vacuum issue? Possibly combined with other issues(spark). You really need some good troubleshooting steps. A good shop manual would be your best investment. But even if you can't get one, there are several people on this forum who are much more knowledgeable than me at troubleshooting these systems and of course several who have shop manuals who can help you out.
post #26 of 31 Old 04-26-2010, 02:44 PM Thread Starter
88yj
No it will not start every time with starting fluid.And it gets fuel but i have no spark again.Iwas just wondering if when the icm gets warm if that can be my problem for not getting spark
88yj is offline
post #27 of 31 Old 04-26-2010, 05:48 PM
Que89YJ
You get power to the coil and spark when you turn the key to start and then it goes away, it sounds like the ignition switch is losing contact when it sprinds back. You need to measure the voltages on the switch under the steering column whe its giving the problem. It matches the symptoms you have decribed almost to a T.
Que89YJ is offline
post #28 of 31 Old 04-27-2010, 11:56 AM Thread Starter
88yj
I changed the ignition control module and that fixed my problem so far drove it for 4hrs today thanks for all the help
88yj is offline
post #29 of 31 Old 04-27-2010, 02:40 PM
dtn8tr
Kewl...must have been all the cheese in it...lol j/k from the other side of the river.
dtn8tr is offline
post #30 of 31 Old 04-27-2010, 05:44 PM
shatteredsoul
Glad you got her all straightened out, happy jeepin once again.
Wrangler wont start...sometimes Skullx TJ Wrangler Technical Forum 12 02-23-2011 12:59 PM
1989 wrangler 4.2 wont start! blackedout89 YJ Wrangler Technical Forum 3 04-24-2009 03:42 PM
98 wrangler wont start when its hot donny81 TJ Wrangler Technical Forum 1 02-26-2009 12:12 AM
02 wrangler wont start idnthaveadd TJ Wrangler Technical Forum 2 08-04-2007 11:49 AM
2005 wrangler... wont start *HELP* gerrynjr TJ Wrangler Technical Forum 17 02-15-2007 04:11 PM
