88 wrangler wont start - JeepForum.com
post #1 of 31 Old 04-15-2010, 03:01 PM Thread Starter
88yj
I Have a 88 wrangler with 4.2 with 2100 carb and juice box .Now the problem is it will crank over but will not start.I changed the starter relay and it started one time now it will not start again .When i turn the key on i do not have no power to the prongs on the starter relay.
88yj is offline
post #2 of 31 Old 04-15-2010, 03:18 PM
shatteredsoul
It may not be this but I had a very similar problem with my 88. It ended up being the ignition control module, I replaced it and put in a reman distributor. I would always start small with issues like this though like checking fuses, wires, grounds,fuel, spark etc. I cant count how many times Ive seen the simplest thing keep a car from running. Also the ignition control module is notorious for going out on these YJs. Mine ran fine then died about 5 times coming home from work one day and wouldnt start again. If your YJ isnt nuttered Id do that but it sounds like it probably is if it has the MC2100 and juicebox.
shatteredsoul is offline
post #3 of 31 Old 04-15-2010, 03:39 PM Thread Starter
88yj
IT is not nuttered yet. I guess my question is what make the starter relay work.When i had power to the prongs after i changed it the jeep started right up now i have now power at the relay again
88yj is offline
post #4 of 31 Old 04-15-2010, 03:43 PM
monkeyhouse
You really should do the nutter bypass, very inexpensive to do and your carb will run much better anyway. If your problem is computer related, it may help that as well.
First Jeep was an 1989 YJ, I've also had a Grand Cherokee. Currently, I have a 99 XJ.
monkeyhouse is offline
post #5 of 31 Old 04-15-2010, 03:49 PM
shatteredsoul
Could it be the fusible links that bolt onto the starter relay? Also I found a way to nutter my newer un-cut harness without cutting a single wire which also kept me from voiding my warranty on my new ignition control module since it has a lifetime warranty. Are you checking everything with a multi-meter or light to try and trace down any wiring issues.
post #6 of 31 Old 04-15-2010, 04:00 PM Thread Starter
88yj
Im useing a light. Where is the ignition control module located and is there a way to test it
88yj is offline
post #7 of 31 Old 04-15-2010, 04:08 PM
jcooklock
1990 XJ Cherokee
definatally check these. Mine just quit on me one day and it took me a week and $200 to finally find what was wrong. Damn fusible links!!
by JDNightFox - The terminal velocity of the square headlights is directionally preportional to the force of gravity decelerating the front wheels while the alternator is spinning at 3000 rpm's, minus the friction of the bumper pushing against the airflow with the 13 volt current the steering column is using during the time the vacuum motor is disengaged, but the mirrors must be directionally angled from the driver's window because the hood latches deflect the light refractioning down through the Nitrogen coat on the hood.
jcooklock is offline
post #8 of 31 Old 04-15-2010, 04:16 PM
shatteredsoul
The module is under the coolant reservoir bottle on the drivers side, its bolted to the inner fender and has 2 connectors on it. I have heard you can take it to Advance, Autozone etc and have it tested for free but I didnt do that. I just took a guess and basically had the Zone order me a new one along with the distributor since they didnt have either in stock. They were both a little over $100 and came with lifetime warranties. I couldnt believe how wore old my ol factory Motorcraft dist. was when I took it out. Jcook the fuseable links is the reason I replaced my whole under hood harness with one that was un-cut, stupid PO had cut them out for some glass type ones like on a car stereo and that had literally melted the glass fuse into the plastic. Its not a wonder why my poor jeep didnt start or run right, but hey Im slowly getting there one piece at a time.
post #9 of 31 Old 04-23-2010, 07:14 PM Thread Starter
88yj
I checked all the fuseible links they are all good. I did the nutter bypass and it still wont start.When i turn the key on i do not get power to the starter relay prongs.does the ignition control module have anything to do with that getting power
88yj is offline
post #10 of 31 Old 04-23-2010, 08:08 PM
shatteredsoul
Could be the actual ignition switch under the steering column which would keep it from getting juice down to the starter relay. Not sure though always start small with fuses, grounds etc.
post #11 of 31 Old 04-23-2010, 08:16 PM Thread Starter
88yj
I there a way to bypass that by push botton or something.I checked all the fuses and i have power to everything lights,radio ect
88yj is offline
post #12 of 31 Old 04-23-2010, 08:24 PM
shatteredsoul
You could if that was the issue but I wouldnt, I would replace it with a factory replacement. There is a rod that runs from where the key is down to it switch. When my ICM went out I thought the switch was bad but it wasnt. There is some topics about it on here somewhere, Id search, test it , and go from there.
post #13 of 31 Old 04-23-2010, 08:28 PM Thread Starter
88yj
Would it be that switch if the starter cranks
88yj is offline
post #14 of 31 Old 04-23-2010, 08:36 PM
shatteredsoul
If the starter is turning over then it shouldnt be the relay, check for fire coming out of the coil and into the distributor. If you have spark there them pull a plug wire and see if you are getting spark at the end of the wire, If you are getting spark there then its a fuel/air issue. Use a plastic handle screwdriver to easily check for fire just dont touch the metal part and dont do it long just have someone help you bump it over a few times.
post #15 of 31 Old 04-23-2010, 08:40 PM Thread Starter
88yj
There is power to the coil but nothing after the coil.I check with a different coil and i got the same thing power to not after
88yj is offline
Wrangler wont start...sometimes Skullx TJ Wrangler Technical Forum 12 02-23-2011 01:59 PM
1989 wrangler 4.2 wont start! blackedout89 YJ Wrangler Technical Forum 3 04-24-2009 04:42 PM
98 wrangler wont start when its hot donny81 TJ Wrangler Technical Forum 1 02-26-2009 01:12 AM
02 wrangler wont start idnthaveadd TJ Wrangler Technical Forum 2 08-04-2007 12:49 PM
2005 wrangler... wont start *HELP* gerrynjr TJ Wrangler Technical Forum 17 02-15-2007 05:11 PM
