88 Wrangler.. 2.5 - JeepForum.com
post #1 of 5 Old 06-30-2013, 08:28 AM Thread Starter
88CapeWrangler
88 Wrangler.. 2.5
Hey guys been a long time since ive been on here.. but anyway i went and put a 2.5 (so they told me it was 2.5..) lift in my wrangler so everything went good except now my sway bar links don't reach, i had to make a bracket for the track bars to fit ( front and back) because they no longer reached and now my pinion angle is a bit too much and its vibrating pretty bad. what should i do ? order a transfer case drop kit or shim it ??
88CapeWrangler is offline
post #2 of 5 Old 06-30-2013, 08:30 AM
Xpress
Remove the Track Bars (seriously, research it around here), buy a set of quick disconnects for the swaybar, and go from there.
All about that unibody life.
Xpress is offline
post #3 of 5 Old 06-30-2013, 08:32 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Transfer case drop: yes
Shims: yes
Track bar brackets: No. Just no.
Sway bar extensions: shouldn't have to
Luck Favours The Prepared
Anticanman is offline
post #4 of 5 Old 06-30-2013, 12:43 PM Thread Starter
88CapeWrangler
ok, ill look into getting both... do i really need track bars anyway , or just get rid of them ?
post #5 of 5 Old 06-30-2013, 12:56 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Adios them to your garage if you have inspections but don't run them on the jeep.
