88 jeep shuts off - JeepForum.com
post #1 of 10 Old 06-17-2008, 01:46 PM Thread Starter
Toocrazy2care38
88 jeep shuts off
my 1988 jeep has a 258 6cylinder and t-5 tranny. it has some electrical problems but other than that the only problem is that when it reaches 3500RPM's the engine wants to shut down. it only does it when in gear, does anyone have any idea what the problem could be?
Toocrazy2care38 is offline
post #2 of 10 Old 06-17-2008, 10:00 PM
timatoe
timatoe's Avatar
Maybe ignition control module???? That's only a guess with the limited info.
timatoe is offline
post #3 of 10 Old 06-17-2008, 11:15 PM Thread Starter
Toocrazy2care38
what more info do you need? it only does it when its in gear. i van put it in neutral and rev it up and it wont do it but in any gear it will.
post #4 of 10 Old 06-18-2008, 03:36 AM
timatoe
timatoe's Avatar
Fill out your profile. Is is a stock engine? Has it been Nuttered? Do you have a different distributor setup, HEI or TFI? All of these may have some effect. For starters a bone stock 258 is going to want to run at 3500 rpm, it don't like to be above 3K. Read up on the "Nutter Bypass" and try that.
timatoe is offline
post #5 of 10 Old 06-18-2008, 06:41 AM
YJ Rider
1987 YJ Wrangler
I had the same thing until I did the nutter, especially the part about replacing the advance spring on your distributor. That will change your RPM range and allow you to use the rest of your tachometer your Jeep has never used.
Live in your world, play in ours...
YJ Rider is offline
post #6 of 10 Old 06-18-2008, 10:22 AM
timatoe
timatoe's Avatar
Also, I should have been more specific before.... It's not so much the 258, but the stock carter carb that's your limiting factor. Again, research the Nutter Bypass.
timatoe is offline
post #7 of 10 Old 06-18-2008, 11:38 AM Thread Starter
Toocrazy2care38
i was going to put a new weber carb with a carter 2 barrel... whould that help?
post #8 of 10 Old 06-18-2008, 01:41 PM
YJ Rider
1987 YJ Wrangler
I did that and while it was an improvement it did not help in that department. The nutter with the TFI upgrade is the best advice I can offer for that issue and would recommend it to anyone with a carb'ed YJ
YJ Rider is offline
post #9 of 10 Old 06-18-2008, 02:17 PM
TorqueWrench87
I had that problem with my jeep.. I did the nutter bypass and got a new ignition module and it fixed it. I still would like to upgrade the carb to a weber for better performance.
1990 YJ 4.2L, Weber 32/36 K551, Nuttered, AX-15... RC 4" lift kit ... Rest is stock
TorqueWrench87 is offline
post #10 of 10 Old 06-18-2008, 10:25 PM
timatoe
timatoe's Avatar
To do this you will have to do the Nutter Bypass. I can't say it anymore than I already have, RESEARCH THE NUTTER BYPASS.
timatoe is offline
help! jeep shuts off 8nine-sahara YJ Wrangler Technical Forum 8 07-21-2009 07:36 AM
Need Help, Jeep shuts off going down the road!!! BamaWrangler YJ Wrangler Technical Forum 10 11-26-2008 12:40 PM
my jeep just shuts off. please help saltysaltine YJ Wrangler Technical Forum 6 07-15-2008 07:41 PM
Jeep shuts off in prime noodles2049 YJ Wrangler Technical Forum 0 08-27-2005 03:08 PM
jeep shuts off with downshifting? 93yj35 YJ Wrangler Technical Forum 1 02-21-2003 06:13 PM
