88 heater core replacement - JeepForum.com
post #1 of 6 Old 12-24-2013, 01:38 PM Thread Starter
calebshadle
Looking for some extra hints on replacing my heater core. I just received my jeep a short time ago and a few things need fixing. Obviously the heater core. I have the blessing of a heater core from another year but still a YJ series. Does anyone know if that will work? If so I will not buy another core. If someone is willing to write a brief walk through or send me a url to a walk through i would be highly appreciative!
calebshadle is offline
post #2 of 6 Old 12-24-2013, 01:56 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
http://www.jeepforum.com/forum/f12/y...-first-580536/
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 6 Old 12-24-2013, 04:34 PM
33chief
1987 YJ Wrangler
Just replaced the heater core in my 87. The cores are cheap enough to buy one that is new. Also, look at changing your blower motor while you have the plenum apart. It took me about 2 hours from start to finish.
This is what I used as a guide to help. It was perfect
http://www.jeepforum.com/forum/f12/heater-core-219329/
33chief is offline
post #4 of 6 Old 12-25-2013, 03:11 PM Thread Starter
calebshadle
any ideas if a 94 will fit an 88?
post #5 of 6 Old 12-26-2013, 01:42 PM
bpounds
bpounds's Avatar
I believe they are all the same on YJ.
But simple enough to figure out if you take 5 minutes and compare the part numbers on a site like www.rockauto.com.
More importantly, I would make sure I used a core that has the mounting flange welded on. Most of the knock-offs don't and they just bounce around in the plenum. Works, but it ain't right.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #6 of 6 Old 01-02-2014, 09:19 AM Thread Starter
calebshadle
thanks for the help! Working on this is a lot easier with all this help! Thanks again!
