88 Grinds when clutch peddle pressed - no does shift
| GR8TOPS Introduces the Exogate HD Tire Carrier | The Original 3/8" Ruffstuff Diff Cover! | Ruffstuff Axle Simple Swap Kit! |
#1 | |
Summary:
Left work, it was a hard shift into first, drove about a mile down the road and went to down shift and the heep started making grinding any time I pressed down on the clutch. If I coasted with the clutch pressed in I would hear the grinding sound, if I put her in neutral and coasted then there was no grinding. It got worse, but I had to get home.. about a 1/2 mile from my house I stopped at a stop light, and vola!! no more shifting and the clutch just dropped to the floor (no pressure). I turned it off and shifted into first, started it and drove the last bit to my house at 10-15mph with the hazards on. Some things I am going to check: - Clutch fluid level - Clutch leaks (just replaced lines and flushed a whole bottle through) Wondering if it could be any of the following: - transfer case (I've been hearing clunking as I shift, mainly into 3rd) - the clutch itself and advise or thoughts would be greatly appreciated EDIT: Just realized I typed the title to fast. Sorry.
88 Wrangler - Build Thread: http://www.jeepforum.com/forum/f12/88-yj-fix-turned-build-956202/#post8758947 |
#2 | |
Look at the firewall under the dash and see if you see clutch fluid, if so, the master went sour. If fluid is leaking from the bell housing, then the slave is bad. |
#3 |
If your clutch grinds when you depress the clutch pedle in, the throw out bearing retaining springs could have rusted off and allowed the throw out bearing to rotate and slip down into the throwout fork. Same thing happened to me on my 98 TJ. Strangest thing that I ever saw. Had to get a new fork. Either way,,your going to need to seperate the bell housing and you might as well replace the clutch disk, pressure plate, and throwout bearing and pilot brg.
#4 |
Its not the master, I replaced that when i did the line... so it could be the slave or as BC suggested the through out bearing.... lucky i don't have to drive it till next Monday, unfortunately i have only Sunday to fix it... well and tonight. so to the garage I will be going.
#5 | ||
All the same, it sounds as though it is indeed the throwout bearing that is bad. Max ![]()
Click here to see all of my different albums on Photobucket. Choose any album to see all of my pics! Mean Max is setting up his Jeep shop! Picture history of my progress here. Quote:
There is no situation that cannot be improved with a small but well-placed explosive.
#6 |
So true on the throwout bearing making noise, but he also stated that he has lost all clutch pressure, so possibly the slave unit with the bearing went belly up.
#7 |
So I might as well just replace the clutch and related parts... that way I get all the old crap out of the way and start nice and fresh.
#8 | |||
#9 |
OK here is the cure, take that Pug tranny and sell it for scrap, take that money and go to a local u pull it and buy an AX15 tranny from a 96 n up Cherokee, take the clutch slave/master and anything else they will let you have. Install the AX15 with external slave and don't look back.
Dwayne
http://www.bobistheoilguy.com/images/lucas/lucas.htm[url] Prevent Flat Tappet Cam Failure. http://www.hotrod.com/techarticles/engine/flat_tappet_cam_tech/oil_summary.html[url] http://www.compcams.com/information/whatsnew/NewsDetails.asp?ListHistoryID=1821071676 http://www.dctra.org/?p=79 http://www.cranecams.com/?show=faq&id=1 |
#10 | |
X-Y-J-Con
![]() ![]() ![]() might have to change transfer case also (i did splines are diff.?)
88yj-94 4.0-ax15-2004 rubicon f/r axles-4.10's-factory air lockers-33"D!ck Cepek Crushers |
#11 |
But with that new valve cover, you can use the money you are saving on motor oil!
------------------------------------- Tim C. Rochester, NY ------------------------------------- |
#12 |
I fixed a leaky fitting. Solved the clutch pressure issue. However the grinding is still there.
Im thinking of getting a new tranny, but I found a new-to-me clutch for $25, and thats more bank friendly at the moment
#13 |
the new valve cover saves me from the nasty looks i get from my clients as I pull out of their parking lots leaving huge oil spots (well not anymore)
#14 |
Whats involved in swapping out the bearing and clutch? drop trans, pull and replace? anything i should be worried about?
#15 |
I would recommend renting or borrowing a pilot bearing puller. I tried the other two common techniques, filling the cavity with grease or cutting the bearing with a dremel, and they both are way harder then necessary. I ended up borrowing a pilot puller at the O'reillys down the street through their tool loaner program. Using the puller it came out within 5 minutes. Getting at the top two bolts on the bellhousing can also be difficult and I found that lowering the transmission slightly gave me a bit more room, however, do not lower it to much as it can cause your fan to make contact with the radiator.
Rick
87 YJ 4.2L, Weber 32/36, rear bumper tire carrier, nutter bypass, RE 4 inch lift, SYE, AX 15, lined the body tub "Baby when you said you wanted a project jeep I expected you to spend a lot of money on it" <---Worlds best wife!!! |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
