88 5 Speed - Tranny Not Engaging After Clutch install (no clutch need to shift) - JeepForum.com
post #1 of 13 Old 10-29-2009, 01:35 PM Thread Starter
kgillette
First off I know I messed somthing up
What I did - Replace the clutch and related (slave, pressure plate, clutch disk, pilot bearing) and replaced the transfer-case with a new to me
Issue: I can shift with jeep running without pressing in the clutch. And I am unable to drive forward/reverse (even if I shift with clutch)
Soo any suggestions on what I could have messed up?
88 Wrangler - Build Thread: http://www.jeepforum.com/forum/f12/88-yj-fix-turned-build-956202/#post8758947
kgillette is offline
post #2 of 13 Old 10-29-2009, 01:46 PM
Jeepman89
I had to bleed and bleed again. did you replace master cylinder too?
Jeepman89 is offline
post #3 of 13 Old 10-29-2009, 01:55 PM Thread Starter
kgillette
The master was replaced before the slave. if it wasnt bleed all the way, would that cause the no power to the tranny? It confuses me as to how I can have the engine running and not have to press the clutch in to shift between the gears, and even more so that when I shift nothing happens
post #4 of 13 Old 10-29-2009, 02:00 PM
AbbyNormalYJ
Check that the transfer case is in 2H/ not neutral.
AbbyNormalYJ is offline
post #5 of 13 Old 10-29-2009, 02:07 PM Thread Starter
kgillette
I did. I put it in 2h 4h and 4l, I got nothin. could the transfer case be bad? I was under the impression that if the transfer-case was bad i just wouldnt have any power to the wheels, it sounds to me like the issue is someplace in the tranny or just before it.
could it be an issue with the clutch disc or the pressure plate?
post #6 of 13 Old 10-29-2009, 02:13 PM Thread Starter
kgillette
or for that matter the slave cylinder?
post #7 of 13 Old 10-29-2009, 06:03 PM
jeepman709
Did you put the pressure plate in the correct way? It is stamped or marked on the side that should be facing toward the tranny.
jeepman709 is offline
post #8 of 13 Old 10-30-2009, 05:33 PM Thread Starter
kgillette
I took it all apart again. and it turns out the new to me t-case is busted... so I put my old one back on.
Now I cant shift though... It feels like I am 1/2 in neutral (i can only move a little sideways) and I can not move between the gears now, not even a budge. Any ideas on what would cause a once fully functional shifter to not work? It worked before I took off the transmission and replaced the t-case (which was working, only swapped because it was older), put it back together and then no shifter.
post #9 of 13 Old 10-30-2009, 05:36 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Read this thread!
http://www.jeepforum.com/forum/f12/b...hifter-885822/
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #10 of 13 Old 10-30-2009, 08:58 PM Thread Starter
kgillette
I know i should have searched... Needless to say i was very frustrated. More so now because what a hassel the clutch install has turned into... think positive - i know alot more about my jeep now
thanks max
post #11 of 13 Old 10-30-2009, 09:01 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
thanks max
You're welcome.
Hang tough, don't let it beat ya down!
Max
Mean Max is offline
post #12 of 13 Old 11-01-2009, 01:29 PM Thread Starter
kgillette
She keeps beatn but i keep beatn her back finally workin!
now its time to find some new shifter retainer clips, do a proper tune-up and put the inside back together
post #13 of 13 Old 11-01-2009, 01:39 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Eh don't worry about the shifter retainer clips... I drove my BA10/5 for a few months without it. I could rip it out of the transmission while driving
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
TJ AX-15 is difficult to shift! Replace clutch, clutch & rebuild, or just suck it up! NORCALROOTS TJ Wrangler Technical Forum 38 12-12-2015 10:07 AM
clutch "lashing" sound when engaging clutch in 1st and 2nd gear 06Rubicono TJ Wrangler Technical Forum 6 11-16-2009 07:24 PM
clutch/tranny install problems heywaitfourme YJ Wrangler Technical Forum 4 06-04-2006 08:51 AM
New problem after tranny install...Clutch master cyliner??? boatingncst8fan YJ Wrangler Technical Forum 3 02-21-2006 08:26 PM
Tranny install, clutch, Misc Q's TellyDSP YJ Wrangler Technical Forum 5 03-21-2005 07:38 AM
