#1 | |
'88 4wd wont engage,
i was out driving around today at a construction site, and went to put it in 4wd, but the light didn't come on, and it didn't engage, im guessing it might be a problem with the vacuum disconnect, this happened once before and i found out the vacuum line came off the axle, so i put it back on but this time i didnt notice it off, i was also messing with some vacuum lines and might have unplugged it, where is it connected on the other end of the hose than the axle?
#2 |
BUILT. NOT BOUGHT.
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs March 1st, 8pm. WILMINGTON, NC MEET & GREET @ HOOTERS! |
#3 |
so i have checked the axle, and the vacuum line is still connected, and 4wd light wont turn on, and it still wont engage, but just a day before i made this thread it was still working just fine, is it obvious to see the vacuum line going to the t-case? could it possibly be something other than the vacuum disconnect?
#4 |
Spray the vac lines from the source all the way down to the axle with water and watch for bubbles and listen for hisses and such. Could just have a leak some where on the line
#5 |
where are the other lines? are they easy to spot? havent had a chance to thoroughly look underneath yet, i know the one to the axle is easy to see, just looking under the hood
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
