88 4 cyl swap transfer case swap to 89 6 cylinder ? - JeepForum.com
post #1 of 2 Old 03-26-2010, 03:20 PM Thread Starter
YjShane
found a 88 4 cyl jeep looking to swap transfer cases from my 89 yj which is broken, IS that ok? mine is a np231 amc'' code the code on the 88 is np231 j'' Both manual 5 spd'
YjShane is offline
post #2 of 2 Old 03-26-2010, 05:11 PM
Toms87
1987 YJ Wrangler
What transmission do you currently have? 4cyl AX5s and the 6cyl BA10/5 used the 21 spline input shaft to the 231 and AX15s used 23 splines. Not sure about what came with the auto transmissions.
Toms87 is offline
Transfer case swap dadstjaz TJ Wrangler Technical Forum 8 11-19-2014 09:07 AM
Swap transfer case xinys JK Wrangler Technical Forum 4 06-23-2009 08:00 AM
transfer case swap gabulldogs YJ Wrangler Technical Forum 3 03-04-2009 11:51 AM
NP-231 transfer case swap BBCAT TJ Wrangler Technical Forum 4 12-09-2008 11:41 AM
Transfer case Swap mtnsammy YJ Wrangler Technical Forum 6 05-21-2006 04:32 PM
