88 4.2 YJ Ignition Module questions - Page 2 - JeepForum.com
post #16 of 19 Old 11-08-2011, 09:00 AM
snag
2010 JK Wrangler
Got a pretty similar thing going on jeepjon. Im going to start working on it tommow. Ill post here the results
snag is offline
post #17 of 19 Old 11-08-2011, 09:30 AM
timatoe
timatoe's Avatar
Originally Posted by JeepJon15 View Post
But is the HEI alone gunna help if i dont upgrade everything else right away?
Yes, because you're getting rid of the failure prone ICM, you can update everything else later.....
Here's some help.... http://www.jeepforum.com/forum/f12/n...today-1217045/
timatoe is offline
post #18 of 19 Old 11-08-2011, 11:08 AM
dancytron
One more thing i thought of that may or may not be connected. Sometimes when i turn the key to start the jeep it seems like theres a power surge where it turns very slowly then speeds up and fires up. As its struggling my lights typically dim a bit then get full power back between engine turns. The starter is only about a year old, maybe a little less. Battery i think is from 04, but can a battery cause shut off problems? It does seem to die rather quickly when trying to get her started on bad days.
That is the classic symptom of bad battery cables. Either replace them or at least replace the ends. If they look original or over 10 years old, just replace them.
Grounding the ignition module like 4x said made a big difference in how mine ran.
I put a new cap, rotor and plug wires on mine when I bought it so put off the Team Rush upgrade for a long time, but it made a big difference too when I finally did it.
dancytron is offline
post #19 of 19 Old 11-08-2011, 09:27 PM
wizekrakr
I once had very similar symptoms on a 76 CJ5. After the engine was warmed up if I hit a bump in the road it would die and not restart for 20 to 30 minutes. Took me forever to figure that one out but it turned out to be a bad connection in the wiring coming out of the distributor at the connection to the wiring harness. If it is nuttered, check all of your connections and especially connections affected by heat from the engine getting hot.
Just my 2 pennies.
Don
wizekrakr is offline
4.2 , ignition module , shut off , starting problems , YJ
ignition module 612 YJ Wrangler Technical Forum 2 03-04-2009 08:56 PM
89 4.2 Ignition module ?'s hillside250 YJ Wrangler Technical Forum 10 12-09-2008 07:16 PM
89 4.2l ignition module maybe??? drews0311 YJ Wrangler Technical Forum 12 07-29-2007 11:46 PM
ignition module went out... BillR YJ Wrangler Technical Forum 0 10-04-2006 06:35 AM
Ignition Module - Help??? JeepR92 YJ Wrangler Technical Forum 12 10-06-2004 10:43 PM
