88 4.2 won't run - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 88 4.2 won't run
Time To Save On Yukon Lockers!Jeep Wrangler Bushwacker Flat Fender Flare Sale at BaselinIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 06-17-2013, 11:24 AM   #76
superj
1987 YJ Wrangler
i don;t think mine gets that hot. you can definitely feel it but not through shoes. i think adding a heat shield under the jeep is the best choice though
I don't feel like working on anything, at this time.
superj is offline   Reply With Quote Quick reply to this message
Unread 06-17-2013, 12:32 PM   #77
jokerchief462
Mine is under the carpet. Does sound and heat.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
[COLOR="Blue"][B]AF Jeep Club Tail #184[/B][/COLOR]
jokerchief462 is offline   Reply With Quote Quick reply to this message
Unread 06-17-2013, 08:08 PM   #78
Tyler980
Thanks for advice guys.
Tyler980 is offline   Reply With Quote Quick reply to this message
Unread 06-17-2013, 08:09 PM   #79
Tyler980
Do you guys know of a site to get a new skid plate? I only ever find them for the oil pan and gas tank everywhere I look.
Unread 06-18-2013, 05:51 AM   #80
superj
1987 YJ Wrangler
for which area of hte jeep?
Unread 06-18-2013, 09:09 AM   #81
Tyler980
Protecting where the Cat is, so basically the mid section.
Unread 06-18-2013, 11:14 AM   #82
superj
1987 YJ Wrangler
isn;t that the plate under the t-case and trans? or are you wanting another one, besides that one?
Unread 06-18-2013, 12:47 PM   #83
Tyler980
I want to replace it... mine has rust and branches that have popped up on trails poked holes through it. Haha.. And it may be that... I'm not sure where/what a t-case looks like or would be. Still learning stuff :P
Unread 06-18-2013, 03:28 PM   #84
superj
1987 YJ Wrangler
When you lay under he jeep, ther is a big plate running across from he passenger side to the diver's side of he frame. Hat is your t-case/trans crossmember(skid plate). It protects your t-case and transmission end from rocks and supports the trans/t-case as the mounts are on top of it. No branches could poke holes in it, it is solid. Check all the aftermarket manufacturers and parts mags for skid plates though because people do make different ones
Unread 06-18-2013, 03:31 PM   #85
superj
1987 YJ Wrangler
This is your t-case. The part sticking out with the red seal is where your rear drive shaft hooks up. The other side is sure the trans hooks up and the left off set is where the front drive shaft hooks up
Unread 06-18-2013, 03:34 PM   #86
superj
1987 YJ Wrangler
The red/silver tag tells you which t-case model you have and the black plug in front of the tag is where your vacuum lines hook up that go to the front driveshaft vacuum connect and engine vacuum lines hook up
Unread 06-18-2013, 04:18 PM   #87
Tyler980
Yeah, I found out it was the crossmember.... as I took it off and the t-case started coming down... I have a jack holding it up now.. theres no way that skidplate is going back up there, it was just getting holes from being so rusted, I'm trying to find a new one now... the motors torqued back and everything, seems like it'll be fun trying to put the new one on when I find one.
Unread 06-18-2013, 04:38 PM   #88
Tyler980
I've been looking online and I can't find any for the t-case... looks like I may have to find a parts jeep with one...
Unread 06-18-2013, 06:10 PM   #89
superj
1987 YJ Wrangler
check ebay
Unread 06-18-2013, 06:56 PM   #90
Tyler980
Seeing some on there, thanks... a new one for 350 dollars... wow
