88 4.2 won't run - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 88 4.2 won't run
Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri2007-2016 Jeep JKU 4" X-series suspension lift **dea
Unread 06-10-2013, 07:39 PM   #46
Tyler980
I have adjusted that, sorry, brain fart. Haha. If I had the cash I would get a new carb in a heart beat... I'm just trying to make this work till I can... But I always have it running and everything perfectly fine, with the sputtering however... then next day comes and its hard to get it to even start.
Tyler980 is offline   Reply With Quote Quick reply to this message
Unread 06-10-2013, 11:50 PM   #47
JeepingJustin
I wonder if you dont have a bad vacuum leak.
JeepingJustin is offline   Reply With Quote Quick reply to this message
Unread 06-11-2013, 05:37 AM   #48
superj
1987 YJ Wrangler
you said you have a pressure regulator set at 3.5? do you need that on the stock carb? might be low pressure?
I don't feel like working on anything, at this time.
superj is offline   Reply With Quote Quick reply to this message
Unread 06-11-2013, 08:45 AM   #49
Tyler980
Don't know what the pressure runs out, don't know how to even check it. Haha
Unread 06-11-2013, 11:08 AM   #50
superj
1987 YJ Wrangler
k, must have been another carb thread, ha ha ha
Unread 06-11-2013, 12:58 PM   #51
JeepingJustin
Ya you dont need it for a stock carb.
Unread 06-11-2013, 03:18 PM   #52
Tyler980
Alright. So I readjusted spark plug gaps to .030. They were all aroun .040. But I'm still having the trouble I always have to get it started. The timing is set right. Idle is about 1k. But starting it always proves to be a big problem.
Unread 06-11-2013, 06:38 PM   #53
superj
1987 YJ Wrangler
Could just be that carb.
Unread 06-11-2013, 07:00 PM   #54
Tyler980
Think I'm just gonna get a carb from the junkyard... I hear Motocraft 2100 or 2150's work great?
Unread 06-11-2013, 07:34 PM   #55
superj
1987 YJ Wrangler
That's what they say. I had better luck with a Holley two barrel from a late 60s dodge v8 but lots of people like the motorcraft. It is a darn goodcarb
Unread 06-11-2013, 08:15 PM   #56
Tyler980
I hear you just need a mr gasket and it bolts right in?
Unread 06-11-2013, 11:22 PM   #57
JeepingJustin
Yup just an adapter. Just about any ford has them, you'll want the non smog version which is the 2100. But either one will work. Also go an find the 1.08 venturi carb.
Unread 06-12-2013, 09:47 AM   #58
Tyler980
Now is the 1.08 venturi carb a whole carburetor? Or something to go with the 2100?
Unread 06-12-2013, 11:17 AM   #59
superj
1987 YJ Wrangler
its like a model of the motorcraft. on the side of the bowl it will say the venturi size, 1.08, 1.21 or a whole host of other sizes
Unread 06-12-2013, 08:19 PM   #60
Tyler980
So I want a motorcraft 2100 with 1.08?
