88 4.2 won't run - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 88 4.2 won't run
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineZONE 4.25" combo lift for TJ available at Rockridge4wTeraFlex Now at Rockridge 4WD! BEST DEALS around!
Unread 06-09-2013, 01:08 PM   #31
JeepingJustin
Originally Posted by Tyler980 View Post
Alright thanks. Yeah there are some small ports on back of carb I need to plug. Do I need to plug the two big ones on too of carb towards the front that use to go down to canister? I plugged it at canister and just took out the big hose that went to those
Plug all the ones you plan on not using.
JeepingJustin is offline   Reply With Quote Quick reply to this message
Unread 06-09-2013, 05:06 PM   #32
Tyler980
Originally Posted by JeepingJustin View Post
The vauum port you have plugged in your pic is what I have to my dizzy. Also someone said check your adapter plates for leaks, I highly recommend that, that is where all my trouble was also. Sounds like the same problem you are having now.
What are adapter plates, and where do I find them? I'm a bit of a noob at this. I have plugged all the unused hoses, I set timing, set idle, its at about 1000... It will stay running but it kind of has a rough idle, its poppy sounding.
Tyler980 is offline   Reply With Quote Quick reply to this message
Unread 06-09-2013, 05:24 PM   #33
superj
1987 YJ Wrangler
The adapter plates are underneath the carb. You will have two of them between the carb and intake
Slow ride, take it easy
superj is offline   Reply With Quote Quick reply to this message
Unread 06-09-2013, 07:08 PM   #34
JeepingJustin
That is if he has a webber. Webbers have 2 adaptor plates. For a MC2100 &MC2150 motorcraft carbs there will be one. What is your timing set at? And have you checked your spark plugs? The gap?
Unread 06-09-2013, 09:03 PM   #35
superj
1987 YJ Wrangler
i thought he said he has a weber earlier
Unread 06-09-2013, 09:25 PM   #36
Tyler980
I'm running the stock Carter Carb, and I haven't checked the gaps on my sparkplugs, I will do that tomorrow or tuesday. My timing is at 8 BTDC like said for the nutter.
Unread 06-09-2013, 09:28 PM   #37
Tyler980
What should the sparkplugs gap be at?
Unread 06-09-2013, 09:34 PM   #38
JeepingJustin
0.033 gap. So you dont habe a weber? If you did the nutter did you also follow the instruction for the carb as well?
Unread 06-09-2013, 09:36 PM   #39
JeepingJustin
That gap is for the stock set up. Not team rush mod (juice box) or hei conversion.
Unread 06-09-2013, 09:44 PM   #40
JeepingJustin
I thought so too. Sorry bout that.
Unread 06-09-2013, 09:56 PM   #41
Tyler980
No weber, It's all the stock parts pretty much, what directions was it for the carb? I just remember the wiring, then plugging the distributor vac line to do timing.
Unread 06-09-2013, 10:30 PM   #42
JeepingJustin
Search the forum for the nutter bypass. Itll show you how to adjust the carter step motor.
Unread 06-10-2013, 05:39 AM   #43
superj
1987 YJ Wrangler
yup, i cannot help on that. i have never had a stock carb on this jeep as it had a weber when i bought it
Unread 06-10-2013, 12:57 PM   #44
JeepingJustin
Yea mine had a weber too, I just know you have to adjust the step motor if youve nuttered it.
Unread 06-10-2013, 05:17 PM   #45
superj
1987 YJ Wrangler
Yup. I read that also
