88 4.2 won't run - Page 3 - JeepForum.com
post #31 of 94 Old 06-09-2013, 12:08 PM
JeepingJustin
Originally Posted by Tyler980 View Post
Alright thanks. Yeah there are some small ports on back of carb I need to plug. Do I need to plug the two big ones on too of carb towards the front that use to go down to canister? I plugged it at canister and just took out the big hose that went to those
Plug all the ones you plan on not using.
JeepingJustin is offline
post #32 of 94 Old 06-09-2013, 04:06 PM Thread Starter
Tyler980
Originally Posted by JeepingJustin View Post
The vauum port you have plugged in your pic is what I have to my dizzy. Also someone said check your adapter plates for leaks, I highly recommend that, that is where all my trouble was also. Sounds like the same problem you are having now.
What are adapter plates, and where do I find them? I'm a bit of a noob at this. I have plugged all the unused hoses, I set timing, set idle, its at about 1000... It will stay running but it kind of has a rough idle, its poppy sounding.
Tyler980 is offline
post #33 of 94 Old 06-09-2013, 04:24 PM
superj
The adapter plates are underneath the carb. You will have two of them between the carb and intake
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #34 of 94 Old 06-09-2013, 06:08 PM
JeepingJustin
That is if he has a webber. Webbers have 2 adaptor plates. For a MC2100 &MC2150 motorcraft carbs there will be one. What is your timing set at? And have you checked your spark plugs? The gap?
post #35 of 94 Old 06-09-2013, 08:03 PM
superj
i thought he said he has a weber earlier
superj is offline
post #36 of 94 Old 06-09-2013, 08:25 PM Thread Starter
Tyler980
I'm running the stock Carter Carb, and I haven't checked the gaps on my sparkplugs, I will do that tomorrow or tuesday. My timing is at 8 BTDC like said for the nutter.
Tyler980 is offline
post #37 of 94 Old 06-09-2013, 08:28 PM Thread Starter
Tyler980
What should the sparkplugs gap be at?
Tyler980 is offline
post #38 of 94 Old 06-09-2013, 08:34 PM
JeepingJustin
0.033 gap. So you dont habe a weber? If you did the nutter did you also follow the instruction for the carb as well?
post #39 of 94 Old 06-09-2013, 08:36 PM
JeepingJustin
That gap is for the stock set up. Not team rush mod (juice box) or hei conversion.
post #40 of 94 Old 06-09-2013, 08:44 PM
JeepingJustin
I thought so too. Sorry bout that.
post #41 of 94 Old 06-09-2013, 08:56 PM Thread Starter
Tyler980
No weber, It's all the stock parts pretty much, what directions was it for the carb? I just remember the wiring, then plugging the distributor vac line to do timing.
Tyler980 is offline
post #42 of 94 Old 06-09-2013, 09:30 PM
JeepingJustin
Search the forum for the nutter bypass. Itll show you how to adjust the carter step motor.
post #43 of 94 Old 06-10-2013, 04:39 AM
superj
yup, i cannot help on that. i have never had a stock carb on this jeep as it had a weber when i bought it
superj is offline
post #44 of 94 Old 06-10-2013, 11:57 AM
JeepingJustin
Yea mine had a weber too, I just know you have to adjust the step motor if youve nuttered it.
post #45 of 94 Old 06-10-2013, 04:17 PM
superj
Yup. I read that also
superj is offline
