'88 4.2 Fuel filter - JeepForum.com
post #1 of 22 Old 06-14-2011, 12:54 PM Thread Starter
Michaelgoesrawr
Michaelgoesrawr's Avatar
'88 4.2 Fuel filter
The fuel filter on my '88 4.2 is in the engine bay correct? Haynes says it is on the frame rail like Mean Max's write up in the FAQ but I didn't see it, unless i'm bind and it's not there (which is highly possible).
I'm trying to get rid of a stutter so I'm going for fuel first. Then I'll go for cap and wires because my plugs are fine.
Thanks for the help.
Michaelgoesrawr is online now
post #2 of 22 Old 06-14-2011, 12:59 PM
dtn8tr
For the '88 4.2 you should see the fuel filter inline just ahead of the carb. It should have an input line on one side and two outputs on the other. One goes to the carb and the second is a return line. When you put in the new filter, make sure that the filter is positioned so that the return line is the top fitting.
1997 TJ, 5" IRO front with 4.5" HD IRO WJ rear, 35x12.5x15 Mickey Thompson MTZ, JKS disconnects
dtn8tr is offline
post #3 of 22 Old 06-14-2011, 01:02 PM Thread Starter
Michaelgoesrawr
Thanks. I've replaced it before, but I was reading though the book and found the other one and was real confused for a second.
post #4 of 22 Old 06-14-2011, 01:06 PM
monkeyhouse
I have the same manual and I know what you mean, but on that 4.2 the filter you are asking about is under the hood.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #5 of 22 Old 06-14-2011, 01:42 PM
dtn8tr
Originally Posted by monkeyhouse View Post
... but on that 4.2 the filter you are asking about is under the hood.
Like I said Monkey...." just in front of the carb." Unless you run your carb attached to the gas tank. But then again Monkeys do strange things!
dtn8tr is offline
post #6 of 22 Old 06-14-2011, 01:54 PM
monkeyhouse
hey now! lol. you posted as I was I guess, no disrespect intended my friend.
post #7 of 22 Old 06-14-2011, 02:00 PM
dtn8tr
Be nice and I'll send you a banana!
dtn8tr is offline
post #8 of 22 Old 06-14-2011, 02:02 PM Thread Starter
Michaelgoesrawr
I picked one up but I haven't change it yet. It's strange. A few weeks ago it started stumbling through all of the gears but only up until 17+ hundred rpm. After that it was fine. Some days it does it horribly and others it accelerates great. As I was driving up to napa it did it but on the way home it was perfectly fine. I dunno. Seemed like a good place to start.
post #9 of 22 Old 06-14-2011, 02:08 PM
dtn8tr
Have you checked plug wires? How old are they? It could be ignition or fuel. It could be a sticking float, too.
if you have a plug wire that moves a little, it could be shorting at times which can cause it to be rough.
dtn8tr is offline
post #10 of 22 Old 06-14-2011, 02:24 PM Thread Starter
Michaelgoesrawr
They are probably as old as the jeep. It sat for five years before I bought it so at least 7 years old. They don't move on the plugs but I didn't check the other end. I guess it wouldn't hurt to change them. When I do, do I get a new distributer and wires or just the wires?
I don't think it's the carb. We rebuilt it only a few months ago.
post #11 of 22 Old 06-14-2011, 02:42 PM
dtn8tr
I would get the distributor cap, rotor, and wires. Actually, if you're going to do that...now would be a good time to do the Team Rush upgrade. Basically you take the old distributor cap off and replace it with a cap and rotor for a 1981 Ford F150 with the 300ci 6 cyl. You also change out the anemic stock coil...I replaced mine with an MSD Blaster2 that ran me $35 at O'reillys. You then get the wires for the same.
dtn8tr is offline
post #12 of 22 Old 06-14-2011, 03:00 PM Thread Starter
Michaelgoesrawr
Do you happen to know if doing that is legal in CA? Obviously the fords have them, but there are so many regulations I'm not sure if it's okay. lol.
So I can pick all the stuff up new at a parts shop? Then gap the plugs at .40-.45. It's supposed to eliminate cross fire right? Any gains in performance?
post #13 of 22 Old 06-14-2011, 03:11 PM
dtn8tr
I didn't look and see that you were in CA. I think that you can do the TeamRush but I know that you can't do the Nutter mod.
It seems to run smoother and revs higher and quicker. i don't know that you see any hp gain or MPG gain but it does seem to be smoother through the rpm range.
...and yes, you can go to any auto parts store for the parts.
dtn8tr is offline
post #14 of 22 Old 06-14-2011, 03:19 PM Thread Starter
Michaelgoesrawr
Thanks a lot. Aside from the stutter/stumble it goes through the rpms fine. I generally don't drive it above 3k anyway. Saves gas
post #15 of 22 Old 06-14-2011, 03:22 PM
dtn8tr
I don't normally go above 3k either but it goes through it faster.
dtn8tr is offline
1990 4.2 new carb, fuel filter, fuel pump barely runs, help. litz YJ Wrangler Technical Forum 18 05-17-2017 10:04 AM
No fuel to filter...fuel pump or relay?? jason280 YJ Wrangler Technical Forum 10 03-25-2011 07:10 PM
Surging and poor performance.....fuel filter? fuel pump? lwoods TJ Wrangler Technical Forum 17 09-09-2009 07:10 PM
Fuel filter replacement - How do I depressurize fuel system? Rproject YJ Wrangler Technical Forum 13 11-23-2008 08:34 AM
fuel pump?fuel filter?relay? garoughrider YJ Wrangler Technical Forum 2 02-26-2008 05:23 AM
