88 2.5l Oil In Airbox? - JeepForum.com
post #1 of 7 Old 03-14-2007, 04:18 PM Thread Starter
FSTG60MAN
My girlfriends 88 yj with the 2.5 has a great deal of oil in the airbox. I replaced the pcv valve on the valve cover and installed a new air filter and cleaned the airbox on sunday. Today there is enough oil in there that it is leaking out on the ground. Any advice will be helpfull. thank you
sold the zj back in a yj, skyjacker 7000 absorbers, bfg 31x10.5x15 all terrains, hella lighting, highlift and more tow straps than god.
FSTG60MAN is offline
post #2 of 7 Old 03-14-2007, 08:37 PM Thread Starter
FSTG60MAN
Nobody ever had this before?
post #3 of 7 Old 03-14-2007, 08:58 PM
Tomb Raider
Addicted...
Tomb Raider's Avatar
Check the vaccuum hoses going too and coming from the engine, specifically on the intake. One of them is kinked or otherwise blocked, would be my guess.
-Scott
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #4 of 7 Old 03-15-2007, 06:44 AM Thread Starter
FSTG60MAN
thanks, ill check those tonight.
post #5 of 7 Old 09-13-2009, 09:15 AM
jesseleikerjeep
Did that take care of the issue FST? I am having a similar problem.
-Jesse
jesseleikerjeep is offline
post #6 of 7 Old 09-13-2009, 10:03 AM
Jeeeeeeeeeeeeep
When the piston rings start getting bad you get blow-by and oil in the air box. I have the same problem. There isn't really a cheap fix for this condition. New rings and a bore job is the only way to fix it.
1991 Jeep Wrangler 2.5L, 5 speed
2003 SVT Cobra Supercharged 32V 4.6L, 6 speed
Jeeeeeeeeeeeeep is offline
post #7 of 7 Old 09-13-2009, 10:34 AM
ZeroGravity
I hope he figured this out. The thread is from 2 years and 6 months ago.
The cheap fix is to make an oil catcher that runs in line with your PCV hoses. I made one for abour $10 out of a large metal jar, two barbed hose fittings and some small hose clamps.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
OEM Airbox ? SuperWade2 TJ Wrangler Technical Forum 7 07-28-2007 08:49 AM
Airbox? Are they the same? onlyn8v TJ Wrangler Technical Forum 2 07-15-2007 07:41 AM
Airbox geabaldyvx YJ Wrangler Technical Forum 21 02-19-2007 07:44 AM
Oil in Airbox? dabomb5756 YJ Wrangler Technical Forum 4 04-23-2005 11:35 AM
Oil in airbox YJ boy YJ Wrangler Technical Forum 5 02-22-2002 11:15 PM
