87YJ Not getting spark - JeepForum.com
post #1 of 1 Old 05-04-2011, 08:24 PM Thread Starter
mike_b_ar
1987 YJ Wrangler
I have an '87, 4.2L, 5-speed. A few months ago, I was driving my jeep and it just died. I thought it was the starter solenoid, so I replaced it, but that didn't fix the problem. Turned out, there was a fusible link that had blown.
Since then, it turns over, but doesn't start. It's not getting spark at the spark plugs. I pulled the cable from the coil, and it doesn't get a spark either while cranking, but as soon as I turn the key back to run, it sparks once.
I've replaced the ignition control module because every post I've seen says to do that first. No change. The coil tests out okay-proper resistance at each terminal.
When the ignition switch is in run, the coil gets about 4V. While cranking, that voltage goes up to only around 7-8V. It should be 6V on run, and 12V while cranking.
I tested continuity between the coil and the started solenoid, and it shows that there is continuity. Is it possible for the continuity that I'm seeing goes through the ICM?
It's very possible that I didn't hook all of the wires up to the solenoid correctly.
Any advice would be greatly appreciated!!!
mike_b_ar is offline
Anyone know if a 85 fiberglass hood will it fit my 87yj strd27 YJ Wrangler Technical Forum 6 02-05-2010 07:54 PM
87yj 4cylinder in a 97tj SET2JET YJ Wrangler Technical Forum 9 09-27-2008 10:51 AM
Fuel sending unit for 87yj docneon YJ Wrangler Technical Forum 11 04-20-2007 04:08 AM
4WD vacuum source '87YJ flexncj7 YJ Wrangler Technical Forum 2 08-16-2006 07:41 AM
My 87YJ project... JeepinGirlinFl YJ Wrangler Technical Forum 17 06-13-2004 09:31 PM
