87 YJ valve cover. - JeepForum.com
post #1 of 11 Old 04-05-2010, 08:55 PM Thread Starter
srfjunkie03
1987 YJ Wrangler
87 YJ valve cover.
I have an 87 YJ Laredo with the 4.2L, I live in AK, and am having a hard time finding the plastic valve cover. Will the aluminum one from an 86 4.2 bolt right on? Or one from a later year?
srfjunkie03 is offline
post #2 of 11 Old 04-05-2010, 09:04 PM
Burnerman
Burnerman's Avatar
No. the 87 shared the valve cover from the CJ's. 88-90 4.2's use an aluminum cover and different mounting bolts. Quadratec sells replacement plastic covers and aluminum covers that are made to specifically replace the plastic ones. Give them a call..
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #3 of 11 Old 04-05-2010, 09:36 PM Thread Starter
srfjunkie03
1987 YJ Wrangler
I just got offline with them, they don't sell one for an 87 any longer. I have no idea where to find one.
post #4 of 11 Old 04-05-2010, 10:03 PM
Lonan
Here you go
Jeep Wrangler Valve Cover for 4.2L at 1AAuto.com.
I bought this one for my 1990 4.2 and it's works great. No tax and free shipping too.
Lonan is offline
post #5 of 11 Old 04-05-2010, 10:57 PM
KillerBBBs
E Bay has them also. 1987 87 Jeep Wrangler Valve Cover 4.2L NEW : eBay Motors (item 110513419229 end time Apr-28-10 11:43:18 PDT)
1988 YJ Sahara 4.2 Khaki Metallic
"Jeepin"..so easy a caveman can do it!
Khaki Jeep Club Member # 121
Sahara Owners Club Member # 44
KillerBBBs is offline
post #6 of 11 Old 04-06-2010, 12:10 AM
NateWithoutBeer
I had to replace it on my 87 as well. I was lucky enough to get a pretty knowledgeable parts person on the line at the local Jeep dealer and they actually had some in stock, so you might want to try your dealer.
If somebody hadn't mangled my 87 I'd pull the part number for you.
NateWithoutBeer is offline
post #7 of 11 Old 04-06-2010, 12:34 AM
Douglas S.
My 87 had a metal cover, not a plastic one.
1991 Land Cruiser HDJ81
Douglas S. is offline
post #8 of 11 Old 04-06-2010, 07:20 AM
wanabejeeper
1987 YJ Wrangler
Funny enough I just ran into the same issue... The reman engine I got was drilled for a plastic cover not an aluminum one even though I ordered the aluminum one. So i can either go with one of these plastic ones or get an aluminum replacement from Qtec..... nother 50-100 I didn't expect to spend
wanabejeeper is offline
post #9 of 11 Old 04-06-2010, 07:26 AM
Mudtracker
1987 YJ Wrangler
Mine does aswell, but its not the original block so Im not sure if the motor is an 87.
Mudtracker is offline
post #10 of 11 Old 04-06-2010, 07:41 AM
wanabejeeper
1987 YJ Wrangler
Both styles were available... I think they continued to use CJ heads untill they ran out. The heads are different only in the location and number of holes. There are 7 holes in the CJ head and about 15-18 in the YJ (plastic cover)
post #11 of 11 Old 04-06-2010, 08:48 AM
Fernando
Fernando's Avatar
1987 YJ Wrangler
Mine is an 87 and I have a metal cover...
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
CCV Fitting, Valve cover to Manifold Cover need help skd+ROO TJ Wrangler Technical Forum 0 11-08-2009 04:13 PM
Broke elbow on pcv valve on front of valve cover... 99JeepWrangler TJ Wrangler Technical Forum 12 01-01-2009 02:17 PM
93, 4 Cyl, YJ Valve Cover Leaking = New Valve Cover?! Jim93YJ YJ Wrangler Technical Forum 10 09-12-2007 04:33 PM
2.5L valve cover Nanuq YJ Wrangler Technical Forum 2 08-05-2006 07:47 PM
Oil on top of valve cover jacknanticoke YJ Wrangler Technical Forum 4 04-04-2005 11:27 AM
