87 YJ Vacuum Routing. HELP!!!! - JeepForum.com
post #1 of 6 Old 07-11-2010, 08:34 PM Thread Starter
Mcloves_09
Hey guys, i've been reading for about 3 hours now trying to figure out this mess of vacuum lines going on in my 87 yj with the 4.2.
I started off with rebuilding the carb, and labeled everything i took off. My only problem now is after reading (and doing) the nutter bypass, i found out my dizzy didn't actually have anything connected to it. and now i'm right confused... i dont have the stock vac routing diagram, i bought a hanes manual, and now i read that i can pull a lot of the hoses out. It's been a long sunday, and i need my jeep for work tomorrow.... any help would be much appreciated. I need to know where my stupid hoses go, and what i can rip off.
Thanks for your time,
Mike
Mcloves_09 is offline
post #2 of 6 Old 07-11-2010, 10:06 PM
Tompatt
1987 YJ Wrangler
which carb do you have? the stock carter?
Thomas
-1987 YJ
Tompatt is offline
post #3 of 6 Old 07-11-2010, 10:09 PM Thread Starter
Mcloves_09
yep, stock carter. half assed got the lines figured out, but now it is running retardedly rich. trying to hit the gas to go it bogs and really wants to stall. GAH! nothing but problems
post #4 of 6 Old 07-12-2010, 08:59 AM
Tompatt
1987 YJ Wrangler
sorry man. i have no exp with the carter. wish i could help.
Thomas
-1987 YJ
Tompatt is offline
post #5 of 6 Old 07-12-2010, 11:24 AM
Fernando
Fernando's Avatar
1987 YJ Wrangler
Did you adjust your ignition timing after the nutter?
You need to provide the distributor with a source of manifold vacuum
Let us know if you adjusted the ignition timing, there must be a source of manifold vacuum on the Carter, I can't remember where it is since I got rid of it a long time ago, but I know it's there.
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #6 of 6 Old 07-12-2010, 09:45 PM Thread Starter
Mcloves_09
I did indeed advance the timing. there is a capped off vacuum hose running indirectly to the intake manifold... by capped off i mean someone pushed it over the battery holder hahaha. i'll try that.
YJ , vacuum , routing
Vacuum hose routing logiplex YJ Wrangler Technical Forum 2 04-19-2013 10:10 PM
4wd vacuum motor hose routing? TorqueWrench87 YJ Wrangler Technical Forum 8 03-10-2011 04:51 PM
Vacuum Routing 90 YJ and other newbie questions RickYJ90 YJ Wrangler Technical Forum 5 06-06-2010 06:48 PM
vacuum routing assistance(CTO) needed schwim YJ Wrangler Technical Forum 9 03-27-2008 12:15 AM
??? Vacuum routing question ??? Bob K YJ Wrangler Technical Forum 3 02-28-2002 08:28 AM
