87' yj, stock rear diff or lsd? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 87' yj, stock rear diff or lsd?
Savvy/Currie Aluminum Control ArmsIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAlloy usa heavy duty ball joint kits
Unread 06-22-2012, 04:32 AM   #1
straightsixjeep
Hello, yesterday I heard some weird noise coming from the rear diff when moving very slow. I decided it was time for a drain and fill, especially since I went through apx. 4ft of water a few wks ago. I stuck my index finger in the fill hole, it was about an inch from the top, but it was also a bit foamy/bubbly (water iv read). Its the stock dana 35 in my 87' jeep wrangler sport. I picked up 80-90 gear oil and im going to add some lucas oil stabilizer. Anyway to tell if Its lsd or am I ok to use the fluid I have? Thank You
straightsixjeep is offline   Reply With Quote Quick reply to this message
Unread 06-22-2012, 08:42 AM   #2
Anticanman
Follow me
Anticanman's Avatar
Nope. Not LSD. Use some brake cleaner to really expel eny water that may have contaminated the area.
Luck Favours The Prepared
[SIGPIC][/SIGPIC]
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 06-22-2012, 03:19 PM   #3
straightsixjeep
That what I needed to know, Thanks a ton!
jeep
