87 yj problems getting into gear - JeepForum.com
post #1 of 7 Old 05-19-2010, 01:07 PM Thread Starter
shawnyj
1987 yj wrangler 4.2 manual tranny.
I initially stared having an issue with shifting a month ago it was somtimes hard to get into 1st and grinding reverse.. it got worse to the point I stared checking out the problem. hydraulic clutch fluid was low so i filled it and it was fine. then it kept draining on ground and in turn i wouldnt be able to get into gear... I realized then it was slave cylinder was leaking. so i had it replaced and the hydraulic master cylinder replaced... I also had a clutch kit put in(it was needed) the flywheel turned and a new starter ring put on flywheel.... then I get it back from shop and I immediately have trouble with getting the tranny into gears intermittently(meaning it works OK 10% of the time) and grinds reverse to the point i cannot get it into gear.. when jeep is off shifts into any gear without a problem. Sometimes it uses up hydraulic fluid(goes on ground while runnning and trying to put into gear) other times it stays full. i can sometimes go into 1st from a stop easily and every third time it wont work. if im upshifting to second from 1st i have to go to third gear because it wont go into second. Ive had trouble getting it out of gear. it feels like the clutch isnt fully disengaging. I dont know where to go from here. any ideas what to do first? then if it doesnt work what next and so on.....? if u need any other info i will supply it.
shawnyj is offline
post #2 of 7 Old 05-19-2010, 01:18 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Master going bad?
http://www.jeepforum.com/forum/f12/c...cement-728960/
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 7 Old 05-19-2010, 01:42 PM
Weavis
I say if you had someone else "fix" the slave and master already...take it back to them and have them make it right. It sounds like something may not have been seated properly if you are still losing fluid or you might have gotten a bad part. I replaced my slave not too long ago and still got no pressure on the clutch. Come to find out, it was a bad replacement part and I had to go through it all over again! Good luck!
"If you can't be good, be good at it!"
Weavis is offline
post #4 of 7 Old 05-19-2010, 05:01 PM Thread Starter
shawnyj
I get clutch pressure on the pedal, but it seems like i need to push it further then the floor allows to disengage clutch. And as far as taking it back to have them fix it.... they went through one slave already.. they tore it apart and put new one in and backed it out and the new slave went right away.. I was covered by warranty on part but what would cause that? so after they put new one in again could it be bad again from ****ty install?
shawnyj is offline
post #5 of 7 Old 05-19-2010, 08:03 PM
Mark05059
either that or the parts themselves are notorious for being bad. If it was fixed by them recently and its still under warranty... then its their problem to fix.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #6 of 7 Old 05-19-2010, 08:27 PM
CSCmrwizard
1982 CJ5
it sounds like air in the line or slave try pumping clutch for a bit the try it
Jeeps dont FLOAT!!!!!!
93 YJ
82 CJ5
CSCmrwizard is offline
post #7 of 7 Old 05-24-2010, 01:54 AM Thread Starter
shawnyj
OK just found out my tranny is an AX15... its an 87 and it should have the BA10/5. So My question would be since it has obviously had a tranny swap, is there a difference in clutch kits between the two? I bought the kit for an 87 but since it isnt the same could this be the issue/ or it is the issue?
shawnyj is offline
D44 Gear Problems, shaft problems. lazerusrm TJ Wrangler Technical Forum 7 04-09-2008 05:29 PM
2 nd gear problems. RedRock84 JK Wrangler Technical Forum 3 02-10-2008 08:58 AM
4th gear problems FranV TJ Wrangler Technical Forum 2 09-08-2007 10:41 AM
2nd gear problems OB1 YJ Wrangler Technical Forum 3 04-11-2005 06:29 AM
4wd low gear problems nyconickk TJ Wrangler Technical Forum 10 12-20-2004 08:44 AM
