87 YJ making a clicking noise when stopping - JeepForum.com
post #1 of 8 Old 05-21-2009, 06:21 AM Thread Starter
SSDDYJ
1987 YJ Wrangler
87 YJ I-6 TF999 and NP-207 making clicking noise from either transfer case or transmission, replaced all brakes and disconnected front driveshaft and nothing helps. Does not make noise any other time only when on the brakes fairly hard. Any suggestions would help
Thanks
SSDDYJ is offline
post #2 of 8 Old 05-21-2009, 06:28 AM
agentr855
could be some really bad end play in your transfer or transmission shafts... does any gear grind when shifting? i had this same problem when 3rd went.
_______ Only in a YJ
/l ,[_____],
l---L -[]lllllll[]-
()_)-()_)--o-)_)
agentr855 is offline
post #3 of 8 Old 05-21-2009, 07:58 AM
championdada
hey SSDDYJ ... what next, did you manage to solve this problem
championdada is offline
post #4 of 8 Old 05-21-2009, 08:13 AM Thread Starter
SSDDYJ
1987 YJ Wrangler
transfer case works fine in 4 high,4 low and 2 high and transmission shifts great, I'm stumped
SSDDYJ is offline
post #5 of 8 Old 05-21-2009, 08:15 AM
unideluxe
How is your transmission mount? Mine was a little loose causing the drive shaft to rotate against the muffler shield when braking causing a 'clicking' noise.
1993 BLACK Wrangler, 1.5" shackle lift, CJ hardtop, rest is stock....dang it college.
Originally Posted by Ribramax View Post
If you ain't bustin' it you ain't usin' it. If you ain't usin' it you don't need it.
unideluxe is offline
post #6 of 8 Old 05-21-2009, 03:55 PM
JRD917
1987 YJ Wrangler
i had the same thing with mine ... before i put mylift on come to find out .... after i installed my lift i got to looking it was one of two things casueing it ...i had bad shock bushings plus i had a bad transfer mount casueing it to rock and tap against the tail pipe from time to time casueing a tapping sound ???? take your pick lol
All jacked up on Mt Dew, And commin at you like a Spider Monkey !!!!
JRD917 is offline
post #7 of 8 Old 10-26-2012, 10:40 PM
lanny94
instead of makin new thread figured id bump an old one so i have a harsh clicking sound when im slowing down seems to do it only in 2 wheel since it only started doin it on the way home after wheeling. o and my pinion angle is completly buggered cause i lost my driveshaft shims those will be getting replaced asap
lanny94 is offline
post #8 of 8 Old 10-26-2012, 11:01 PM
mrmark
You have to make sure the DS is right and then retest as it could have been your problem all along.
it would be hard to tell what is wrong if everything else is not correct.
Wave as you pass me :D
The problems of owning 2 Jeeps ... I never know which one to work on or which YJ gets the next mod ...
mrmark is offline
RE Superflex Joints making clicking noise at low speeds JVRuby TJ Wrangler Technical Forum 3 01-20-2010 11:04 AM
rattling/clicking noise from t-case when applying the brakes stopping bobsbungalo TJ Wrangler Technical Forum 0 05-27-2009 08:17 PM
Popping/Clicking Noise when making sharp turn esad_b TJ Wrangler Technical Forum 7 04-01-2009 06:29 PM
Jeep making clicking noise DKilleen TJ Wrangler Technical Forum 3 10-10-2007 07:24 PM
Clicking Noise When Turning/Stopping? SimonTuffGuy YJ Wrangler Technical Forum 9 03-28-2007 10:51 AM
