'87 YJ fuel tank pressurized after dropping tank? - JeepForum.com
post #1 of 10 Old 10-05-2010, 10:51 AM Thread Starter
Gooch
1987 YJ Wrangler
I dropped my tank to clean it about a month ago... I noticed that it smells a little like fuel and when I take the cap off the tank it hisses like the tank is pressurized! The other day, the damn thing sputtered, cut off and now won't restart! It's a 1987 YJ with 20 gal plastic tank, Weber 32/36, nuttered 6 cyl.
Why would there be pressure in the tank? I redid all of my lines except the metal ones when I dropped the tank. I need help!
Gooch is offline
post #2 of 10 Old 10-05-2010, 11:58 AM
MJMPC
Sounds like you kinked a vent line. Pull it again and see.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #3 of 10 Old 10-05-2010, 12:05 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Yep, kinked vent would cause alot of this.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #4 of 10 Old 11-09-2010, 08:08 AM Thread Starter
Gooch
1987 YJ Wrangler
So I dropped my tank again, and the vent was pinched. I cut out the pinched section and re-installed the tank. Now the thing will start, but will only run for about a minute and then cut off. If it sits for a few minutes and I pump the gas pedal, it will start again and run for a minute and cut off. What the heck is going on?? Any ideas?
Gooch is offline
post #5 of 10 Old 11-09-2010, 08:18 AM Thread Starter
Gooch
1987 YJ Wrangler
Could it be bad gas after sitting for a few months?
Gooch is offline
post #6 of 10 Old 11-09-2010, 09:57 AM
kcaverly
Sounds like it still isn't venting enough. It has a little bit of venting, but not enough to keep it running.
Pumping the gas pedal will use the accelerator pump in the carb to put the last little bit of fuel in the carb into the engine.
Try leaving the gas cap off and see if that helps.
Kevin
kcaverly is offline
post #7 of 10 Old 11-09-2010, 10:23 AM
MJMPC
Now you may have pinched a fuel line. Take the fuel line off the carb side of the fuel pump hold it in a container and have some one crank the motor over a couple of times see if you have any gas comming out.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #8 of 10 Old 11-09-2010, 03:15 PM Thread Starter
Gooch
1987 YJ Wrangler
So I guess I am dropping the tank again tomorrow! Thanks for the replies guys...
Gooch is offline
post #9 of 10 Old 11-09-2010, 10:58 PM
MJMPC
Did you check and see if your are getting fuel through the pump?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #10 of 10 Old 11-10-2010, 05:19 PM Thread Starter
Gooch
1987 YJ Wrangler
I dropped my tank again today... pinched return line and fuel line! Thanks for the help guys... she ran for 30 minutes without a hiccup... tomorrow she's going on the road!
Gooch is offline
Dropping Fuel Tank Kevins87 YJ Wrangler Technical Forum 3 06-05-2010 02:26 PM
Dropping Fuel Tank TA-YJ YJ Wrangler Technical Forum 7 11-17-2009 09:41 AM
Dropping Fuel tank Coastie01 TJ Wrangler Technical Forum 5 07-29-2008 05:03 PM
Dropping Fuel Tank klklett1 YJ Wrangler Technical Forum 14 12-16-2006 08:38 AM
Dropping fuel tank tomkirkland4 TJ Wrangler Technical Forum 7 07-26-2005 02:23 PM
