87 YJ fuel tank and lines running to fuel pump - JeepForum.com
post #1 of 3 Old 05-27-2007, 02:58 PM Thread Starter
87yjjeep
1987 YJ Wrangler
My 87 YJ was running great when I decided to install rear bumper. I could not get my fat hand on the backside of frame to install nut on bolt that holds bumper bracket. So I decided to loosen fuel tank skid plate, when I did tank also came down. I was able to finish bolting bumper on and able to get tank and plate mounted. When I went to drive jeep it would run for maybe 2 minutes and die when i drove it, I thought it may have pinched fuel line at tank. But before I did anything else i checked fuel pump and it would pump as I turned engine over for about 45 seconds and stop. Oh, byt he way this is a mechinical fuel pump. Am I thinking right about fuel line? If so any way of determining where line is pinched? Help!!!!!!!!!! thanks , Gary
87yjjeep is offline
post #2 of 3 Old 05-27-2007, 03:03 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
only way to do it right is to lower the tank a little so you can see the lines.
sounds like either a pinched fuel or return line. blocked vent would also do the same, would create a vacuum in the tank starving the motor of fuel.
could try running it with the fuel cap off, venting the tank, but the end result is the same, lower the tank ON A JACK and fix the problem correctly...
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #3 of 3 Old 05-27-2007, 03:07 PM
drew2000
drew2000's Avatar
x2 on the pinched vent line.
Drew
1994 YJ - 2.5L, 2" BDS w/1" Shackles
2006 Dodge Charger R/T (5.7L Hemi)
drew2000 is offline
'04 Gas Tank Fuel Lines... thejafe TJ Wrangler Technical Forum 2 04-14-2007 11:35 PM
Anyone have a pic of the fuel lines,etc on top of gas tank? wwiihistory YJ Wrangler Technical Forum 11 09-24-2006 06:27 AM
Need braided steel fuel lines (from tank to frame lines) drew2000 YJ Wrangler Technical Forum 4 06-18-2006 08:38 AM
Need fuel lines and tank kg6mti YJ Wrangler Technical Forum 1 11-21-2004 09:08 PM
Help! Lock nut on fuel tank for fuel pump H8PVMT TJ Wrangler Technical Forum 6 07-16-2004 12:21 PM
