87 YJ Fuel Gauge Issue - JeepForum.com
post #1 of 9 Old 02-02-2011, 12:51 PM Thread Starter
Mules50
1987 YJ Wrangler
I have an 87 YJ wrangler 4.2L I6. I am thinking that something is wrong with my fuel gauge or fuel sending unit.
My symptoms are:
Fuel gauge is not very responsive. It either sits at full or drops down to empty. There is no rhyme or reason to it. Some days I will fire it up and it will read full, others empty.
I was just wondering what I could do to test to see wether or not it is the gauge or something more serious. And by serious, more complicated and time consuming to fix.
IMO, I do not believe it is the gauge. If the gauge was broken, I believe that it wouldn't move at all. But I am not familiar with any gauges, so just looking for some opinions on what it actually broken or ways I can troubleshoot to figure out what is broken.
Any thoughts/opinions/suggestions are greatly appreciated.
Thanks.
Mules50 is offline
post #2 of 9 Old 02-02-2011, 01:33 PM
lesterss
Yjs have notoriously bad sending units that read gas level in tank and send that info to the guage, I use my trip milage and fill up as appropriate.
Or you can drop the tank spend a few hundred and get a new one.
lesterss is offline
post #3 of 9 Old 02-02-2011, 01:59 PM Thread Starter
Mules50
1987 YJ Wrangler
Thats what I was thinking too. But the only requirement you need to follow the odometer is to have the odometer working correctly, which mine doesn't . I was thinking of just getting a Jerry Can and just getting some gas every couple of days or so.
If it was just the gauge, then I might replace but seeing as its probably the sending unit, inside the tank, then I prob not gonna worry bought it.
Mules50 is offline
post #4 of 9 Old 02-02-2011, 03:51 PM
Mark05059
whats the matter with the odometer?
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 9 Old 02-02-2011, 04:33 PM
SpideYJeep
From what I've read recently, the things to do (simplest to most difficult) are:
1. Clean up the contacts at the gauge.
2. Confirm that the harness leading to the tank is connected above the tank (you may need to drop the tank to do so).
3. Sending unit - you've addressed that you're "not gonna worry" so I won't.
Wrenching isn't the problem, it's the brains attached to the hands...unfortunately, I'm lacking some of the former so that's why I'm asking you guys!!
Originally Posted by YJake View Post
My YJ is so excited it's leaking oil!
SpideYJeep is offline
post #6 of 9 Old 02-02-2011, 05:57 PM
kloppk
It may be the ground connection on top of the fuel pickup/level sensor assembly.
The ground is connected to a small metal tab.
Sand and mud builds up on top of the tank which cuases the tab to rust off cuasing teh level sensor to lose it's ground..
Could be the problem...
I've run into this issue on 2 different YJ's. Had to carefully tack weld the tab back on.
kloppk is offline
post #7 of 9 Old 05-07-2013, 09:34 AM
krahnj
my problem is my odometer and spedo plus gas gauge doesnt work. gas gauge just stopped working the other day when i went wheeling. pretty sure it was because i hit a stump on the gas tank skid. usually when i hit bumps in the road it starts working again but this time its stuck at empty. i need ideas on what i can do to fix.
krahnj is offline
post #8 of 9 Old 05-14-2013, 09:16 AM
daviddoughty1
1987 YJ Wrangler
Might check the connection between tub harness and fuel tank {left rear behind wheel well} Mine was loose at the plug and acted weird too
daviddoughty1 is offline
post #9 of 9 Old 05-14-2013, 10:46 AM
Que89YJ
Odod and speedo is either your cable or the gear on the tcase, its all mechanical. The fuel sender unit x2 with kloppk. Drop the tank and check the conector on the top. It sounds like its bad. You can short the sender wire to the guage to ground and if it goes to empty then it's time to drop the tank or cut the access hole to get at it.
Que89YJ is offline
91 YJ 2.5 Fuel Gauge wiring issue WillInFla YJ Wrangler Technical Forum 3 10-31-2009 09:00 AM
Fuel Gauge Issue staufson YJ Wrangler Technical Forum 0 10-02-2009 08:18 PM
Fuel Gauge Issue trgcobra TJ Wrangler Technical Forum 7 01-11-2009 04:16 PM
Fuel gauge issue danny2go YJ Wrangler Technical Forum 2 10-10-2008 09:16 PM
Fuel Gauge Issue YJ Brillo YJ Wrangler Technical Forum 1 01-21-2008 12:11 PM
