87 YJ crank but wont start? - Page 2 - JeepForum.com
post #16 of 17 Old 10-08-2013, 05:47 PM
chevybaha
had simular problem
Check all the grounds I changed the cap rotor and distributor still nothing checked all the grounds and had one a little loose dispute the 20 other grounds it started right up hope to help
chevybaha is offline
post #17 of 17 Old 10-09-2013, 03:53 AM
Que89YJ
Thanks for posting the fix. More important how did you figure it out? Did you take the icm in and get it tested?
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
HELP!!4.0 will crank but wont (start)! only on second try staralfur TJ Wrangler Technical Forum 12 07-14-2013 09:00 AM
2.5 will crank wont start Greatdane2002 TJ Wrangler Technical Forum 2 12-19-2009 06:33 PM
2.5 will crank but wont start RockHill YJ Wrangler Technical Forum 0 06-22-2009 11:41 AM
2.5 will crank wont start JEEP9783 TJ Wrangler Technical Forum 2 04-13-2009 09:59 AM
4.0 wont start or crank Teddy TJ Wrangler Technical Forum 2 03-10-2009 10:41 AM
