87 YJ crank but wont start? - JeepForum.com
post #1 of 17 Old 06-06-2012, 07:15 PM Thread Starter
chosos
1987 YJ Wrangler
87 YJ - 4.2 stock carb. nuttered.
I had it running last weekend, and now it wont start. It will crank all day but won't start. I can smell fuel so I know its getting fuel. Also tried starting fluid - no go.
Tried a new ignition coil - no go.
There's isn't a whole lot electrical on this thing to go wrong.
this is my first non EFI car, so excuse my ignorance. Im just looking for some common things to ccheck
chosos is offline
post #2 of 17 Old 06-06-2012, 07:18 PM
rlongsr
If the distributor wasn't changed, it does have a computer that runs it. Check to see if your getting spark.
rlongsr is offline
post #3 of 17 Old 06-07-2012, 07:33 PM Thread Starter
chosos
1987 YJ Wrangler
it seems that I am not getting spark. I'm getting spark at the coil, but not at the plugs.
I have a multimeter, inline spark tester, and a test light. I'm willing to tear into it, but need some suggestions.
Today I replaced the distributor cap, the rotor, and the plugs - since the old cap had some fouling and its a fairly cheap part.
The ignition coil is also new.
chosos is offline
post #4 of 17 Old 06-07-2012, 08:52 PM
rlongsr
There is a pick up in the distributor, check all the connections to make sure the are intact and not rusted out. I think advance or autozone can check those, not sure.
rlongsr is offline
post #5 of 17 Old 06-07-2012, 09:11 PM Thread Starter
chosos
1987 YJ Wrangler
a pickup in the distributor? can you elaborate any more than that? if i google those terms, I get all sorts of info for pickup truck distributors. :-)
chosos is offline
post #6 of 17 Old 06-07-2012, 09:23 PM
rlongsr
Not sure exactly what it is called. But take of the cap and rotor, and it is under there. Has wires on both sides of it.
rlongsr is offline
post #7 of 17 Old 06-08-2012, 07:01 AM Thread Starter
chosos
1987 YJ Wrangler
one more question:
the more i read on this, the more is sounds like it could be the distributor or the ignition control module. I soldered in the nutter mod, so I'm not thinking its a bad connection, but the module could have gone bad.
I also get some hesitation under hard acceleration, but I haven't gotten around to looking into that issue yet. One thing at a time.
Is there any way for me to test the ICM or the distributor to rule out one or the other?
Granted... it could also be something else entirely, but i figure i'll start here.
chosos is offline
post #8 of 17 Old 06-08-2012, 08:02 AM
Que89YJ
You can take the ICM to a good parts store. They have testers for it at Autozone. You are getting spark at the coil then it is probably not the coil, its the pickup in the distributor or...you did the nutter did you ground the distributor? It's a side note on the writeup if you read it all the way through.
Que89YJ is offline
post #9 of 17 Old 06-08-2012, 08:03 AM
Que89YJ
BTW; what city are you in in the Big Mit?
Que89YJ is offline
post #10 of 17 Old 06-08-2012, 08:06 AM Thread Starter
chosos
1987 YJ Wrangler
I'm pretty much right where 696 and 94 meet up in St. Clair Shores
chosos is offline
post #11 of 17 Old 06-08-2012, 08:14 AM Thread Starter
chosos
1987 YJ Wrangler
I was pretty sure I did. The jeep started after the nutter job was done. Would it be an all or nothing type deal or would it potentially have this issue?
I know the PO really mangled a lot of the wiring and vacuum lines. I had a hell of a time trying to figure out what was going on in there when I did the nutter job.
chosos is offline
post #12 of 17 Old 06-08-2012, 08:17 AM
kp954
1993 XJ Cherokee
its either fuel or spark. youll figure it out. GL
kp954 is offline
post #13 of 17 Old 06-08-2012, 08:27 AM Thread Starter
chosos
1987 YJ Wrangler
well, im not getting spark out of the distributor, so i've nailed it down to something in that area.
just dont know if its an ICM, distributor, or something else. was running 4 days ago.
chosos is offline
post #14 of 17 Old 06-08-2012, 09:07 AM
Que89YJ
If the distributor is not grounded, do it. The ICM is putting out spark; then the next thing after the ground is the pickup in the distributor.
Que89YJ is offline
post #15 of 17 Old 06-08-2012, 09:27 AM Thread Starter
chosos
1987 YJ Wrangler
Update: problem fixed. It was the ignition control module. Starts right up now.
chosos is offline
HELP!!4.0 will crank but wont (start)! only on second try staralfur TJ Wrangler Technical Forum 12 07-14-2013 09:00 AM
2.5 will crank wont start Greatdane2002 TJ Wrangler Technical Forum 2 12-19-2009 06:33 PM
2.5 will crank but wont start RockHill YJ Wrangler Technical Forum 0 06-22-2009 11:41 AM
2.5 will crank wont start JEEP9783 TJ Wrangler Technical Forum 2 04-13-2009 09:59 AM
4.0 wont start or crank Teddy TJ Wrangler Technical Forum 2 03-10-2009 10:41 AM
