87 YJ Build - Page 4 - JeepForum.com
post #46 of 127 Old 08-10-2009, 11:24 PM Thread Starter
Douglas S.
Does anyone know if this steering will work on the d44? I think it should be fine, but I'm not sure if the 44 is too wide knuckle to knuckle compared to the 30
http://www.jcroffroad.com/Merchant2/...tegory_Code=S6
1991 Land Cruiser HDJ81
Douglas S. is offline
post #47 of 127 Old 08-11-2009, 12:27 AM Thread Starter
Douglas S.
I've also decided to outboard my springs as opposed to moving the perches on the axle. The drivers side perch looks like a lot of material would need to be added and the spring outboard should also offer some stability.
post #48 of 127 Old 08-11-2009, 12:48 AM
antec
here are some nice outrigers from ruff stuff thay have 4.5" and 7"
http://www.ruffstuffspecialties.com/...39521afb3fef24
antec is offline
post #49 of 127 Old 08-11-2009, 01:15 AM Thread Starter
Douglas S.
I think I'll probably just make my own, it doesn't look too difficult.
post #50 of 127 Old 08-11-2009, 06:13 AM
kmj153
http://www.pirate4x4.com/forum/showt...oneer+steering
Here is a link from pirate about steering. I will be doing the same thing to my YJ so I am watching this closely.
1990 YJ, Waggy 44's, 4.56, ARB's, 35's, 4.2 w/ Howell FI, Stak Dana 300 RAC, w/ JB 4:1 and 32 spline output, undercoverfab belly up
2005 F-150, DD/Tow rig
kmj153 is offline
post #51 of 127 Old 08-14-2009, 05:43 PM Thread Starter
Douglas S.
Finally got my soft top installed. I've had it for a couple months, but had to get some pieces repaired. I also have windows and half doors (currently prepping for paint).
post #52 of 127 Old 08-24-2009, 05:02 PM Thread Starter
Douglas S.
After reviewing my plan so far, I have a few things to consider. My local regulatory body is currently in the process of putting restrictions on lifted vehicles. Nothing is final yet, but speed restrictions for vehicles with tires 35"+ seem likely as well as an inspection to get junkers off of the roads. That is fine by me (well, other than the speed restrictions) the only problem is that the local inspectors really have no idea what they are talking about and it makes me a little nervous as to how my vehicle might be evaluated. Nonetheless, I am still going to push on with this build, but I might stick with 33" tires until the legislation is passed and all the details are finalized.
I'm also considering (depending on price) going for the new MT/Rs with kevlar over the KM2's, but I'll have to see the price gap before I make any decisions.
As far as my axles go, I am at my wits end trying to get the carrier out of the front end and may end up getting a shop to do it as my pry bar isn't cutting it and I don't own a spreader. If anyone has any other methods for removal they would be appreciated.
-Douglas
post #53 of 127 Old 08-26-2009, 09:05 PM
kasbiker38
if you are going to change the r&p hit the pinion shaft it will pop it right out
kasbiker38 is offline
post #54 of 127 Old 08-29-2009, 12:17 PM
WVYJ
a buddy of mine used that same style set up with soa and they rubed the springs
WVYJ is offline
post #55 of 127 Old 09-04-2009, 10:22 PM
jharsany
To get out a stubborn carrier, try putting a wrench on one of the ring gear bolts and rotate the pinion to drive the wrench into the pumpkin. The torque generated by the pinion rotating the ring gear will usually pry the carrier out. Good Luck!
jharsany is offline
post #56 of 127 Old 09-06-2009, 10:50 PM
johnjk
that method has always worked for me
johnjk is offline
post #57 of 127 Old 10-08-2009, 11:01 PM Thread Starter
Douglas S.
Ok, I've got an update for you.
Got a set of 4 33x12.5-15 old style mt/r's (they didn't have five). They were really cheap (new old stock) so I couldn't pass it up.
Here they are mocked up on one side of the Jeep (checking for clearance)
Ordering RE 4.5" XD Tomorrow, should be here in a couple weeks
post #58 of 127 Old 10-09-2009, 11:53 AM Thread Starter
Douglas S.
As far as clearance goes, they don't fit too badly. If I trim the rear flares I should be fine until my lift arrives. Tire coverage isn't an issue either because my local police don't enforce it. I'll still add extended flares in the future.
Yes, that is snow in these pictures
post #59 of 127 Old 10-27-2009, 12:04 AM
MoonyJohn
MoonyJohn's Avatar
Nice build so far, clean paint job too. The newer wheels and tires make it look really good.
MoonyJohn is offline
post #60 of 127 Old 10-27-2009, 12:09 AM Thread Starter
Douglas S.
Thanks! Your rig already got my vote for GCOTM
Updates:
After paying for all my school stuff I have come to the conclusion that my 44 is going to be more of a long term project- i want to build it once and that means an arb and other expensive things that are not in the budget right now
My lift was backordered, but should be shipping by the end of the week
As well, i picked up a 4.10 dana 30 and am currently searching for an 8.8 with the same gearing- they seem pretty hard to find
My YJ Build - Yet another build thread!! bluexj YJ Wrangler Technical Forum 28 07-11-2012 01:23 PM
My YJ Build provinT13 YJ Wrangler Technical Forum 1203 06-14-2011 10:29 PM
06flex's build (my build up) 06flex TJ Wrangler Technical Forum 131 07-03-2010 11:26 PM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 03:21 PM
how would you build it? dharmabum TJ Wrangler Technical Forum 4 07-28-2006 12:05 AM
