87 yj brakes intermittently dragging/seizing - JeepForum.com
post #1 of 8 Old 08-25-2013, 06:02 PM Thread Starter
pmm_lord_raven
Hey,
I have an 87 yj. I had issues with not being able to drive much over 40mph. I took the front brakes apart and my rotors were warped and pads cracked to hell. I replaced the calipers, and pads, and rotors.
It was still dragging. I went to replace the hoses, and couldn't get them off the lines. So I replaced the brake lines and hoses to both sides. I flushed the fluid but the problem still happens, sometimes when I hit the brakes too many times, it will go from normal to rock hard. Other times right away. But here is the weird part...they were dragging wicked bad today, and when I pulled over I went over the rumble strips the brake pedal went from rock hard to normal, and they stopped dragging. I relubed the caliper pins, and drove it around. It was fine for a little and then same story, dragging again. I went and hit a few potholes and still dragging. Back to rumble strips and they released.
The proportioning valve was replaced 2 years ago along with the rear wheel cylinders, lines, and shoes. I have no freakin clue what my problem is. Any suggestions?
pmm_lord_raven is offline
post #2 of 8 Old 08-25-2013, 06:14 PM
jokerchief462
The fact that they go from rock hard to normal and were dragging I would say the brake booster has failed.
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 8 Old 08-25-2013, 06:15 PM Thread Starter
pmm_lord_raven
I should clarify, when the pedal went normal the brakes did stop dragging. And when the pedal was hard, it didn't take much effort to slow down and stop. I disconnected the vacuum line to the booster, and my brakes still drag. But I did notice something.
post #4 of 8 Old 08-25-2013, 10:01 PM
ReDinTX
Looks like the master is leaking.
-ReD
Fire Lieutenant/Paramedic
San Antonio, Tx
'90 Yj 4.2L 5spd
ReDinTX is offline
post #5 of 8 Old 08-25-2013, 10:58 PM Thread Starter
pmm_lord_raven
Would that cause the brakes to drag?
post #6 of 8 Old 08-26-2013, 02:32 AM
Mark05059
change both the booster and the master cyl.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #7 of 8 Old 08-26-2013, 03:37 PM
ReDinTX
if theres trash in there that causes the piston to hang up, yea. fluid is turning black cause its absorbing LOTS of moisture because its leaking out which means moisture is getting IN.
I agree
-ReD
San Antonio, Tx
'90 Yj 4.2L 5spd
ReDinTX is offline
post #8 of 8 Old 08-26-2013, 10:16 PM
jbolty
jbolty's Avatar
if the piston in the master can't fully return it will accumulate pressure and start dragging. The same thing happens if the push rod from the booster is adjusted too long.
good time for a dual diaphragm upgrade
jbolty is offline
brakes , dragging
