87 YJ Accelerates when its on Idle... - JeepForum.com
post #1 of 10 Old 04-25-2011, 06:00 PM Thread Starter
sernaeric
1987 YJ Wrangler
Whats Up Guys!! I just bought my 2.5 YJ and it recently started to accelerate on it's own while the jeep is on and on idle. It goes up to 2000 RPM's and scares the hell out of me because there is nothing I can do to stop it or bring it down, so I just end up turning the engine off. I checked the accelerator cable to see if it was sticking but it is not nor is the pedal. Any ideas out there of what could be causing this and how to fix??
sernaeric is offline
post #2 of 10 Old 04-25-2011, 08:11 PM
moonshinefuel
So after you shut it off, and start it again, it idles fine?
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #3 of 10 Old 04-25-2011, 08:59 PM
Jeepin_XJ_101
Is it a stick shift? I didnt think they made auto's for the 2.5 until later. If it was an auto it would make sense that it pulled forward at 2K RPM so you would only have to figure out why its shooting up that high (you would have to anyways), but with a stick and it pulls forward you may be having issues with the slave cylinder or clutch system.
"When in doubt... Floor it"
1989 XJ 4.0L I6 -
- NP231 - 4" RC - 33x13.50 MT Claws
*SOLD*
2005 WK 4.7L 3.5" RK, 255/75R17 on Rubi Wheels
1992 YJ 4.0L 5" ProComp on 35x12.50 Trxus MT
Jeepin_XJ_101 is offline
post #4 of 10 Old 04-27-2011, 09:35 AM Thread Starter
sernaeric
1987 YJ Wrangler
Thanks for the replies! Its not an Automatic and when I shut it off and turn it back on, the RPMs go up right away. I means It was driving fine up until a few days ago.
post #5 of 10 Old 04-27-2011, 09:47 AM
Michaelgoesrawr
Couldn't a vacuum leak cause a high idle too?
Michaelgoesrawr is offline
post #6 of 10 Old 04-27-2011, 09:49 AM
JFcavedweller
does it rev up when you are in neutral? or just in gear?
O|||||||O - '99 TJ
■|||||||■ - '97 ZJ
JFcavedweller is offline
post #7 of 10 Old 04-27-2011, 03:25 PM Thread Starter
sernaeric
1987 YJ Wrangler
Revs up when i'm in neutral. Also when i come to a stop and I take it out of gear....
post #8 of 10 Old 04-29-2011, 12:43 PM Thread Starter
sernaeric
1987 YJ Wrangler
So I checked all my vacuums and they are all in tact. I downloaded a diagram online so I followed that. Other than that is still doing the same thing... now it just idles on 2000rpms.... its rediculous...
post #9 of 10 Old 04-30-2011, 09:43 PM
Jeepin_XJ_101
If your vacuum lines are all in tact and not leaking then its probably the TPS (throttle position sensor). You can take some carb cleaner and spray it around the intake and manifold or any of your other hoses and if the idle drops when you hit the area with cleaner then there is your vacuum leak.
Oh I think I get it now, when you say it accelerates on its own then you mean the RPM's kick up, not that the actual jeep accelerates forward, I take back my comment about the clutch system
1989 XJ 4.0L I6 -
*SOLD*
post #10 of 10 Old 05-01-2011, 10:20 PM
klrstew
My 92 has a fluctuation as well. Idles at 1100 which sounds a little high anyways and often revs up to 1500 for no apparent reason and sticks there for about 2 mins. This seems to be pretty common, but my searches are not going well. Yes, i'm a noob!
klrstew is offline
acceleration , idle , YJ
rubicon speedo accelerates faster than a ferrari! ozo101 TJ Wrangler Technical Forum 19 04-11-2015 10:21 AM
My TJ accelerates on its own JimmyJazz TJ Wrangler Technical Forum 5 10-22-2012 06:35 PM
TJ accelerates when braking?! doggone_tj TJ Wrangler Technical Forum 50 09-26-2010 07:49 PM
High idle 2k rpm, idle jumping on braking - Moab in jeopardy AndrewMuadDib TJ Wrangler Technical Forum 9 09-06-2009 10:19 AM
4.2l Stumbles briefly then accelerates Ironman23 YJ Wrangler Technical Forum 8 06-27-2008 11:52 PM
