87 yj 4.2l pros and cons - JeepForum.com
post #1 of 7 Old 03-27-2009, 11:51 AM Thread Starter
silbotta
Hey im thinking about getting another jeep could you guys tell me from your opinions what are the pros and cons of an 87 Yj with a 4.2l i6....
Thanks in advance
94 YJ
06 Cummins
silbotta is offline
post #2 of 7 Old 03-27-2009, 11:57 AM
CheapSunglasses
2007 XK Commander
Thanks in advance
Pro: Easy to work on
Con: Easy to work on
Seriously....I have an '89 4.2, BA/10-5 and I love it....It runs crappy in the cold until it warms up, and the Carter carb is finicky....Other than that, I love mine.
"The Bannana Channell, Programming With Appeal"....Stay Tuned For a Bunch More!
CheapSunglasses is offline
post #3 of 7 Old 03-27-2009, 11:58 AM
Levinz11
Go 91 or newer. Much less headache from FI. JMHO
You'll also get an AX-15
PLEASE DEPOSIT $.75
Levinz11 is offline
post #4 of 7 Old 03-27-2009, 01:28 PM
mikebigh
mikebigh's Avatar
1987 YJ Wrangler
I have an 87, 258, auto trans. I love it. Some swear by FI, but a well tuned carb can be close, if not just as good. I reach in, turn the key, wait a few minutes and kick it down. Drive.
Rock Krawler Suspensions
mikebigh is offline
post #5 of 7 Old 03-27-2009, 02:14 PM
Tompatt
1987 YJ Wrangler
I love my 87. Carb. im 17 and have done everything to it myself... i LOVE it. yjs are WAY easier than tjs to work on... not alot of junk. just CHECK FOR RUST on the old yjs.
Thomas
-1987 YJ
Tompatt is offline
post #6 of 7 Old 05-18-2009, 07:04 PM Thread Starter
silbotta
94 YJ
06 Cummins
silbotta is offline
post #7 of 7 Old 05-18-2009, 07:10 PM
ImpactFabWorks
I also love my 4.2. And some 4.2s already have the ax15 I believe they started using it in 89 but not sure. But I love my motor even tho I am planning a v8 swap in the next year
ImpactFabWorks is offline
4.2 Pros/Cons JakeMurray24 YJ Wrangler Technical Forum 19 06-05-2009 08:06 PM
Pros and cons of 4cy -vs- 6cy ut1031 YJ Wrangler Technical Forum 33 02-28-2007 12:52 PM
between these two, the pros and cons wrangler2007 TJ Wrangler Technical Forum 22 02-18-2007 04:42 PM
Pros Vs. Cons of RE and Nth JeepRocks86 TJ Wrangler Technical Forum 6 12-22-2006 08:16 AM
Keep '98 TJ or Buy '06 TJ? Pros & Cons BLAINE TJ Wrangler Technical Forum 12 02-22-2006 05:14 PM
