87 Wrangler carb trouble - JeepForum.com
post #1 of 10 Old 05-03-2007, 10:02 AM Thread Starter
RH31379
1983 CJ7
I recently purchased an 87 Wrangler, 6 cyl. Knowing that when it get warm it has trouble starting unlless I hold my foot to the floor and crank for a while. Any idea on what what is wrong or how to fix this? Also I parked the jeep tuesday night and now it won't start period, just cranks and cranks and I smell gas. I think the two are realated. any help would be appreciated.
RH31379 is offline
post #2 of 10 Old 05-03-2007, 10:42 AM
xxxflhrci
xxxflhrci's Avatar
Replace carb with Weber. Problem solved.
xxxflhrci is offline
post #3 of 10 Old 05-03-2007, 10:55 AM
timatoe
timatoe's Avatar
IF that's an option, if it's not due to emissions, extra cash, etc.... GO HERE. That kit worked wonders for my stock carb and it's cheap and super easy to install. I put mine on in under 20 minutes in a light rain.
timatoe is offline
post #4 of 10 Old 05-03-2007, 11:01 AM Thread Starter
RH31379
1983 CJ7
thanks, my hope is a cheaper solution then the weber. Does the carter kit adress my problem? it idles great but will not start after I run it.
RH31379 is offline
post #5 of 10 Old 05-03-2007, 11:33 AM
89' YJ Junker
Check all your vaccuum tubing and hoses. I had a cracked hose when I had a problem similar to yours. Replaced it and I'm running fine now.
89' YJ Junker is offline
post #6 of 10 Old 05-03-2007, 10:55 PM
paintguy
definitely check vacuum hoses and replace-- pull carb and clean and tighten screws -- install new base gasket set and get the venturi tube/screen kit and install it for the $35 -- finally, make sure the choke is working properly.
Good Luck and keep us posted!
Pray For World Peace and Love -- This is all the World Needs, and ever needed -- Everything else will follow...
paintguy is offline
post #7 of 10 Old 05-03-2007, 10:59 PM
Matt87YJ
Matt87YJ's Avatar
1987 YJ Wrangler
Check your fuel filter too..
'87 Wrangler, Stroked with a few other toys...
Matt87YJ is offline
post #8 of 10 Old 05-03-2007, 11:08 PM
4.7stroker
Cheaper option and just as good as the webber is the motorcraft 2100/2150 conversion.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #9 of 10 Old 05-04-2007, 04:25 AM
jay-h
Theoretically an alternative carb will fix things but it's a lot less work to fix the one you've got.
My guess is that the choke is starting to re-close WAY too soon (I have seen this happen in another car). Park the car for 15 minutes after fully warming up and check the choke. It should be still wide open. If not, it is adjusted way too rich or is broken.
jay-h is offline
post #10 of 10 Old 05-04-2007, 06:49 AM Thread Starter
RH31379
1983 CJ7
Thanks Guys,
I got it started again, The choke seems to be messed up and flooded it out, I'll take a closer look at it tomorrow and may strart looking into an alternative carb
RH31379 is offline
Yj. Carb trouble rexryman YJ Wrangler Technical Forum 7 03-15-2009 09:39 PM
trouble getting gas to carb 4.2 wessy YJ Wrangler Technical Forum 0 09-19-2008 05:28 PM
Seasonal Carb Trouble NJscott YJ Wrangler Technical Forum 4 07-17-2008 01:51 PM
New Rebuilt Carb trouble Talos YJ Wrangler Technical Forum 13 05-29-2008 05:46 PM
Carb Trouble Willmac24 YJ Wrangler Technical Forum 6 01-11-2008 07:45 PM
