'87 Power Steering Leak/ Squeal... - JeepForum.com
post #1 of 3 Old 01-21-2010, 10:02 AM Thread Starter
Gooch
1987 YJ Wrangler
So my '87 has sprung a leak somewhere around the base of the power steering pump housing... I have been feeding it Lucas power steering stop leak for a couple of weeks without luck of stopping the leak. Yeah, I know, I was bamboozled on that stuff! Anyways it now has a squeal and it sounds as if it is harder for the belt to turn the power steering pump. (Possibly due to the increased viscosity of the new fluid?) I looked in the cap and the fluid is moving inside the housing... So should I attack the unit with a new set of seals or just get an entire new housing/ pump? It is warming up a bit this week so I can finally get outside to get a closer look.
Gooch is offline
post #2 of 3 Old 01-21-2010, 10:45 AM
DivineKaos
Any chance it sounds like the squeal in this? YouTube - Me coming through a bog..
Turned out that was my power steering pump. Have a friend start it while you are looking at the pump- for me I was able to see it being torqued out of alignment on the bracket- the pinion itself was bent- had to get a new pump
Make sure the leak isn't from a hole in a hose..
"A man has to know two things in life, limitations and priorities. You let your priorities get in the way of your limitations." - MrBlaine
DivineKaos is offline
post #3 of 3 Old 01-21-2010, 03:18 PM Thread Starter
Gooch
1987 YJ Wrangler
Thanks for the reply... it doesn't sound quite like that noise though.
Gooch is offline
Power steering leak / Steering knocking. AustinCJer TJ Wrangler Technical Forum 13 01-12-2010 06:59 PM
Power Steering Fluid (Miniscule) Leak from Steering Column??? JRostron30 TJ Wrangler Technical Forum 3 07-10-2009 12:20 AM
Power steering leak on '98 TheMatrix TJ Wrangler Technical Forum 5 04-02-2009 09:23 AM
Power Steering squeal, driving me nuts KenF YJ Wrangler Technical Forum 2 01-26-2009 11:05 PM
Power Steering Leak Help Plz.. JEEPJUICE999 YJ Wrangler Technical Forum 2 02-25-2008 01:03 PM
