87-91 yj sound bar? - JeepForum.com
post #1 of 12 Old 05-31-2008, 01:18 PM Thread Starter
Bmitch-92yj
87-91 yj sound bar?
Was a sound bar an option on and of the packages from 87-91? I was thinking that it was an option on the Sahara package.
Bmitch-92yj is offline
post #2 of 12 Old 05-31-2008, 01:31 PM
Burnerman
Burnerman's Avatar
I don't know if it was offered but the 95' family style rollbar I just installed has one. You could drill the sportbar to mount one from a later year. The factory bar is OK... 2 -4 1/2" speakers. I just wish I had the interior light!
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #3 of 12 Old 05-31-2008, 01:33 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
No it was not, but as said above, you can install a 92-95 bar with little to no issue.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #4 of 12 Old 05-31-2008, 03:23 PM
sam.b.
or you can install a TJ sound bar if you have the correct plugs or you know how to wire things properly
98 TJ Mild DD
90 YJ Sold
88 Samurai slowly being built for the rocks
<< Louisville Ky. based 4x4 club
sam.b. is offline
post #5 of 12 Old 05-31-2008, 05:32 PM
Prouzy
Prouzy's Avatar
1987 YJ Wrangler
Not sure if it was an option for back then... But I just finished installing my new VDP soundbar, two 6 1/2's and maplights... speakers sound good but I'm to lazy to finish wiring up the lights at this point.
Live Free or Die
RJC #449
Prouzy is offline
post #6 of 12 Old 05-31-2008, 10:47 PM
cjist1
cjist1's Avatar
I ended up just making my own. The money I saved making it let me spend it on some JL component speakers. The dome light I used is out of an older DSM I think. It works really good, but it was a pain in the *** to make sorta. Plus it vibrated until I put Dynamat inside it. Sounds great now though.
92 YJ 2.5L 5 spd.
75.6hp/100.0 ft,lbs.
cjist1 is offline
post #7 of 12 Old 05-31-2008, 11:41 PM
Godholio
The speakers wont last, unless you like having to strain your ears even when you're not moving.
Godholio is offline
post #8 of 12 Old 06-13-2008, 08:30 PM Thread Starter
Bmitch-92yj
the reason I was asking was because I just traded my family bar for a sport bar with somebody and the pads were set up for a sound bar. The guy said it came like that OEM. The forward pads are shorter in the back while the bars themselves have 2 holes on either side in the back, while the main part of the bar has two slits in the pads for where you wrap the back of the sound bar in. I just thought it was a little weird because I haven't ever seen an older yj with a sound bar.
post #9 of 12 Old 06-13-2008, 08:33 PM
bcwheeler
My 91 has a soundbar. I have always thought that it was stock though I did buy the jeep used so im unsure. It has no overhead light, only speakers.
bcwheeler is offline
post #10 of 12 Old 06-13-2008, 09:16 PM
90sahara
my 90 sahara has a sound bar with real small speakers, like 4 1 /2 in., they sounded really bad so i unhooked them..it also has light in the middle..i dont know if its stock though
90sahara is offline
post #11 of 12 Old 06-14-2008, 07:14 AM
YJdad
I had to install mine over the front seats, in front of the center hoop, due to the 94' family bars being to close together (TJ bars are straight back) - I got it before they came out with the separate pods...just a note.
94' YJ Stock 2.5L -
/ BFG 30x9.5x15 / Herculiner / Stereo console - Currently parked for overhaul
98' ZJ GCL - Stock V8
75% of the world is covered by water, the rest is covered by Jeep!
YJdad is offline
post #12 of 12 Old 03-22-2011, 10:48 PM
heretik665
i wired mine into the existing dome light wires and it works just fine Quadratec Part No: 14119.0101
heretik665 is offline
New Sound System: 6 1/2 speakers in sound bar?? Tips please mrbriteside1465 YJ Wrangler Technical Forum 2 11-08-2010 01:32 PM
Screeching sound. Sound changes with clutch movement. skream YJ Wrangler Technical Forum 10 04-20-2009 09:15 PM
Sound Bar vs. Sound Wedges Hoobly_Goob YJ Wrangler Technical Forum 21 02-06-2008 05:58 PM
Infinity Sound System...how does it sound? otizzy JK Wrangler Technical Forum 16 03-11-2007 10:56 PM
sound bar vs. sound wedges harvyjeep TJ Wrangler Technical Forum 3 03-30-2002 09:42 PM
