87-90 Carb Swap Questions - going to older BBD CJ type w/o stepper motor - thoughts - JeepForum.com
post #1 of 3 Old 11-17-2009, 11:58 AM Thread Starter
JrTjK
1978 FSJ Wagoneer
Hi guys,
I was wondering if any of you with 4.2's swapped in a BBD type carburetor WITHOUT the stepper motor and if you had any problems.
There are new ones available online that are the BBD type and they are a stock replacement to the older CJ ones, and I've known a few people that swapped them in essentially to dumb down the carb and have it run better and more efficient than the ones with the stepper motor. As far as I know, they just left the plugs there and tuned the carb and used them as is...but I wanted to confirm with any of you on here if you have done that as well.
I'm not interested in any other carbs like the Motorcraft, Holley, Weber, I just need the info on the Carter BBD type.
I'm wondering does this need to be combined with the Nutter Bypass, or is that just something to do additionally to help?
Thanks!
JrTjK is offline
post #2 of 3 Old 11-17-2009, 02:26 PM
Darold
BBD carb
I have an 88 YJ and put an old non-stepper BBD on with the nutter and it runs very well. Also did the stealth HEI module. If the new type of carbs are like the old ones it should be OK.
Darold is offline
post #3 of 3 Old 11-17-2009, 03:22 PM
bigh20rnr
bigh20rnr's Avatar
1987 YJ Wrangler
Have heard of it being done before and you should be fine. Not sure what vehicle you are doing it to, but if its set up the same as the later model CJ's and early YJ's just make sure you bypass the computer so it doesn't mess with your ignition. AKA Nutter bypass
Rick
87 YJ 4.2L, Weber 32/36, rear bumper tire carrier, nutter bypass, RE 4 inch lift, SYE, AX 15, lined the body tub
"Baby when you said you wanted a project jeep I expected you to spend a lot of money on it" <---Worlds best wife!!!
bigh20rnr is offline
BBD carb stepper motor question spshultz YJ Wrangler Technical Forum 5 08-29-2010 03:37 PM
Jeep carburetor stepper motor Missouribound YJ Wrangler Technical Forum 1 05-26-2009 07:08 PM
Carb stepper motor pins ? Tuffy YJ Wrangler Technical Forum 5 07-09-2008 07:40 AM
carter without stepper motor? oldfrt47 YJ Wrangler Technical Forum 1 11-01-2003 08:22 AM
Stepper motor with nutter bypass Qcwrangler YJ Wrangler Technical Forum 3 06-11-2003 08:22 PM
