87 4.2 yj died and won't start please help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 87 4.2 yj died and won't start please help
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 01-16-2015, 02:41 AM   #1
Tofu77
I have a 1987 yj with the 4.2L with no nutter.
Today I was driving around when I took a turn and started to accelerate as I went to shift to the next gear I felt like the engine lost 75% of its power. I tried to rev my engine to give it some gas and as I did that it just shut off. I let it sit for awhile before trying to start it, engine was cranking and had power to everything but didn't want to start. I tried to push it down a hill and drop the clutch to see if maybe I could at least get home.
I have no idea what could possibly be wrong, I just replaced my ignition switch (located on top of the column) a week ago and has been running a lil rough but otherwise fine. If anyone could help me with some ideas would be great.
The jeep is my daily driver so I need to get her back up and running
Tofu77 is offline   Reply With Quote Quick reply to this message
Unread 01-16-2015, 03:32 AM   #2
Tofu77
Also ik it's getting fuel, because i took the filter off and could see the gas, could hear the starter working just jeep didn't want to start. Even after I had a friend tow me home I tried popping the clutch and got it to fire fire at 10 mph but was barely running and when I would push the clutch in no matter if I even put the gas pedal to the floor it just dies.
Any suggestions are welcome, I've thought it would be icm maybe but it's not that old
Unread 01-16-2015, 05:00 AM   #3
timatoe
Ignition Control Module
timatoe is online now   Reply With Quote Quick reply to this message
Unread 01-18-2015, 01:53 PM   #4
Tofu77
Well after further inspection of the engine and trying to find the problem. I have found that 3 of my passenger engine mount bolts all snapped off and the distributor had fallen onto the engine mount. And I think that has caused it to also jump timing. And the fun part is I have brown dog engine mounts already and the bolts broke
Unread 01-18-2015, 02:25 PM   #5
Mark05059
sounds like some drilling and easy outing is in your future
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline   Reply With Quote Quick reply to this message
Unread 01-19-2015, 08:55 PM   #6
Tofu77
Easy drilling? It doesn't seem to be easy. If anyone has any useful tips on getting the bolts out without dropping the engine would be greatly appreciated just doesn't seem like you can get to all the bolts while the engine is still in the jeep
Unread 01-19-2015, 09:06 PM   #7
Mark05059
remove the fender(s)
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Unread 01-19-2015, 11:58 PM   #8
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Depends on where the bolts snapped off. If you are lucky, there may be some small nubs there you can grab onto with some vicegrips and back them out. Just be sure to hit them with your PB Blaster type creeping oil of choice and/or use the blue wrench on them to help get them out. If, on the other hand, they broke off flush or a little inside the block, you'll need a quality "easy-out" tool and some patience - PB Blaster and heat are still your friend in this case as well.
Best method if you don't want to pull the engine is to remove the fender and attached items to allow clear access to the engine block side. Replace with Grade 8 bolts and use some anti-sieze.
Best of luck
91 YJ "Alice" 2.5L, AX5, 2.5" OME 36Rs, Revolvers, 32" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R Busted Knuckles YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is online now   Reply With Quote Quick reply to this message
Unread 01-20-2015, 06:49 AM   #9
fishadventure
An easy-out is a broken bolt extractor.....
A slab of wood under the oil pan can be a good short term way of jacking up motor without damaging anything.
How many old threads actually convince *you* to read all 36 pages? http://www.jeepforum.com/forum/f12/length-envy-build-thread-629700/
fishadventure is offline   Reply With Quote Quick reply to this message
Unread 01-21-2015, 01:38 PM   #10
Tofu77
Well looks like I'll be running to the store to buy some easy-out tools to pull these bolts because all 4 broke flush with the block. Thank you all for your help, seeing how I'm not that mechanically inclined
Unread 01-21-2015, 02:18 PM   #11
dancytron
Do not break the easy outs off in the hole. They are super hardened steel and are virtually impossible to drill out.
It is one of those things where there would be no shame in going to a pro if you aren't confident you can do it without screwing it up.
dancytron is offline   Reply With Quote Quick reply to this message
