87 2.5 rocker arm torque? - JeepForum.com
post #1 of 4 Old 09-17-2012, 09:02 PM Thread Starter
kodyowenby10
1987 YJ Wrangler
Had my valve cover off so I removed rocker arms to clean them up. The bolts were way more than the torque spec of 19ft lbs coming off. To reinstall do I need to bring each cylinder to top dead center and torque them? 19ft lbs just dont feel right at all.
kodyowenby10 is offline
post #2 of 4 Old 09-17-2012, 11:56 PM
jokerchief462
Just checked the service manual and yes you are right 19 ft/lbs is the correct torque. If they were tighter than that hopefully it didn't stretch the threads. You will be fine at 19 ft/lbs. The serrvice manual does not require TDC for installation only that they go back where they came from.
jokerchief462 is offline
post #3 of 4 Old 09-18-2012, 06:34 AM
EABiker
The initial break-away torque may have been higher due to crud on the threads; I wouldn't worry about it. As stated, no TDC required for re-installation.
EABiker is online now
post #4 of 4 Old 09-18-2012, 05:17 PM Thread Starter
kodyowenby10
1987 YJ Wrangler
At 19 ft lbs it breaks before it even starts to compress the valve springs on the ones I know were compressed when I pulled them loose? The base of the rockers should bottom out on the head before break away torque is reach correct?
Cheap, Entry Level Rocker Guards/Rocker Panels Croce JK Wrangler Technical Forum 14 03-03-2010 09:38 AM
Does socket extension on torque wrench change torque? itasor TJ Wrangler Technical Forum 44 09-25-2009 02:20 PM
Torque converter bolt torque misprint! planedog YJ Wrangler Technical Forum 7 03-16-2009 12:48 PM
Looks Of Plastic Rocker Vs. Real Rocker Guard jbpdog TJ Wrangler Technical Forum 12 06-01-2006 11:53 PM
rocker arm torque specs? ncjeepinyj YJ Wrangler Technical Forum 2 03-08-2006 08:58 AM
