87 2.5 Liter YJ belt squeel - JeepForum.com
post #1 of 5 Old 01-07-2013, 07:37 PM Thread Starter
akm446
So I have an 87 YJ with the 2.5 liter and aftermarket a/c. Something that sounds like I'm killing a pig comes from the engine but only when I hit the gas at lower RPMs accelerating. When the lights were on the lights would then get bright quickly at idle. I found that one of the belts was all torn up where the belt actually makes contact with the points. Can anyone tells which belt it is and if its hard to replace? Or how much it cost to pay to replace it? It would be much appreciated.
akm446 is offline
post #2 of 5 Old 01-07-2013, 08:27 PM
johnny27030
I recommend replacing that belt that is chewed up. Since you are there you may as well replace the other with a matching brand. Shouldnt be to hard to replace. 30 minutes of time and general hand tools at the most. Once the belt is removed spin all pulleys and see if they spin freely or if they have any side to side movement or can rock back and forth any. If so that needs to be replaced.
That belt needs to be replaced badly before it leaves you stranded!!
johnny27030 is offline
post #3 of 5 Old 01-07-2013, 08:57 PM
Xpress
The lights are an indication of your alternator not turning quickly enough, when the squealing occurs watch the voltage gauge. If it drops, you've got yourself a loose belt- the chewed up belt needs to be replaced ASAP.
All about that unibody life.
Xpress is offline
post #4 of 5 Old 01-07-2013, 11:50 PM
Drix
I agree replace the chewed up belt then tighten the belts up.
95' YJ 4" lift 33"x12.5r15's D30/8.8 locked with 4:88's
USMC Jeep Club #6
"Why in hell can't the Army do it if the Marines can. They are the same kind of men; why can't they be like Marines."
Gen. John J. "Black Jack" Pershing, USA; 12 February 1918
Drix is offline
post #5 of 5 Old 04-30-2013, 08:29 PM Thread Starter
akm446
A
akm446 is offline
