8.8 yoke???? - JeepForum.com
post #1 of 6 Old 05-08-2002, 09:19 AM Thread Starter
jeepthang23
8.8 yoke????
I am istalling an exporer 8.8 in my 95 yj. the yoke on the 8.8 is a different setup than on my jeep driveshaft. I have been told you can replace the yoke in the rarend with a new yoke from NAPA. I evenwas given a spicer part#(2-2-1379), but this does not match up. Can anyone please help?
95 sahara hard top 4.0 six inches of lift with 35" tires. awaiting v-8
jeepthang23 is offline
post #2 of 6 Old 05-08-2002, 09:27 AM
SethNCSU
I got the flange thing from a ford driveshaft when i bought my 8.8, I haven't installed my 8.8 yet, but it appears that the ujoint should fit fine inside of it. There is a picture of what it looks like on <a href="http://www.mountainoffroad.com/catalog/Mounting%20Hardware-Axle/Mounting%20Hardware.htm" target="_blank">this page</a>
SethNCSU is offline
post #3 of 6 Old 05-08-2002, 05:24 PM
YJNotDone
Try looking around on this site. <a href="http://www.yankeetoys.org-mangler-88swap.htm" target="_blank">web page</a>
95, 4" susp. lift, 33x12.50 ProComp M/T's, custom square tube bumpers, , energy bushings, 4.0 HO, everything stock, 1" or 2" body lift and who knows what else coming soon.
YJNotDone is offline
post #4 of 6 Old 05-08-2002, 05:27 PM
YJNotDone
Sorry, that didn't work. Try looking up key word "yankee toys". If that doesn't work try "mountain offroad". I think they have some info on this.
post #5 of 6 Old 05-08-2002, 08:14 PM
SethNCSU
There are some good links on page two of <a href="http://www.dpgoffroad.com/tech/8.8.htm" target="_blank">this write up.</a>
SethNCSU is offline
post #6 of 6 Old 05-08-2002, 10:23 PM
Tailgummer
The yoke just bolts to the 8.8 flange after you have pressed the driveshaft U-joint into it. The final dimensions are so close to the D35 that your drive shaft will not need to be changed.
Good Luck
Chuck
'91 YJ, 4.0L 5sp, Atlas II, RE SOA + 2"BDS, 35" Explorer Xterrains, ARB's & 4.56 gears, WARN 9000i
WWW.4x4xnorthwest.com
Tailgummer is offline
hack and tap yoke??? th350 yoke or front t-case output yoke on rear?? 02wrangler_guy TJ Wrangler Technical Forum 5 02-15-2016 03:09 PM
Swapping in 8.8 and need yoke to yoke measurements oo 4Banger oo TJ Wrangler Technical Forum 4 02-24-2009 07:31 PM
Exploded my slip yoke housing and pinion yoke. durangoyj YJ Wrangler Technical Forum 53 01-12-2009 02:58 AM
How do I install ujoint into yoke adapter on rear DS (no straps on yoke)? beertinted TJ Wrangler Technical Forum 4 05-21-2007 09:18 PM
h yoke ????? Why J? YJ Wrangler Technical Forum 91 01-05-2006 09:25 PM
