8.8 u bolts/brackets - JeepForum.com
post #1 of 7 Old 10-24-2011, 10:34 AM Thread Starter
moonshinefuel
Will the stock 8.8 brackets work with the 8.8 conversion? The Ford u bolts, and the Ford brackets? I am thinking they should.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #2 of 7 Old 10-24-2011, 10:40 AM
jbolty
jbolty's Avatar
I used the stock ford bottom plates and they work fine. BUT, the shock mounts hang down like a shovel. I got the MORE relocator brackets and new plates from Ruff Stuff about a year and a half ago and have not put them on yet.
You really should never reuse u bolts and the ford ones are not all that beefy anyway.
Not a great picture but you can see how low the shock sits.
jbolty is offline
post #3 of 7 Old 10-24-2011, 11:35 AM
Quail
If you are staying SUA. Yes
If money is tight, you can use the bolt plates,ubolts and the shock mounts on the plates until you can set it up to youre taste.
I did it for 8 months.
Quail is offline
post #4 of 7 Old 10-24-2011, 12:04 PM
Louie4
Just like these guys said, you can use re-use them. I actually used the plasma cutter and took off the ears for the shock mounts on the plates and I'm ashamed to say that I am still using the stock u-bolts. I want to get the 8.8 u-bolts and spring plates from Ruff Stuff but I'm about to get some synthetic rope and possibly a rear bumper/tire carrier in the next couple months.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #5 of 7 Old 10-24-2011, 12:31 PM Thread Starter
moonshinefuel
Thank you very much, this axle is pretty much ready to bolt in. I bought the brackets and u bolts from a yard. 50 bucks total. It will get me through until I get better it looks like. My 35 is in bad shape, I have to swap it asap. So I have the flange, the brackets, u bolts, and the u joints look to be the same size on the flange as on my current shaft. So now I need to get oil, and I am looking for hopefully someone who is stocking spicer u joints today.
Also. Does anyone know what oil to use in the 8.8 with a arb locker? And are there any additives?
I am out and about right now, and am shopping for this stuff.
Bow Hunting
post #6 of 7 Old 10-24-2011, 12:34 PM
timatoe
timatoe's Avatar
I use the regular 75/90 gear oil, no additives.
timatoe is offline
post #7 of 7 Old 10-24-2011, 02:25 PM Thread Starter
moonshinefuel
Thanks, 75/90 it is then.
I won't need the shock mounts on the plates as I already have the shock mounts welded on the tubes. So I can work with trimming down the brackets some, then get better u-bolts.
No sye, so, I am using the stock drive shaft, stock t case on the 2.5 suspension lift. It looks like the front pinion area of the 8.8 is going to be a little closer to the t case than the Dana 35. But with the 2.5 lift, and the slight offset of the pumpkin on the 8.8, I am hoping it will be a good fit for the driveshaft. I have not read of any problems with this config.
Bow Hunting
Ok so I need some help. Front LCA brackets w/ provisions for cam bolts reewik TJ Wrangler Technical Forum 5 09-24-2011 06:35 PM
KC Daylighter mounting bolts to big for KC windshield brackets LURCH634 TJ Wrangler Technical Forum 5 10-17-2009 03:12 PM
Busted Bolts!!! Backseat Brackets... bucks11 TJ Wrangler Technical Forum 2 10-15-2008 06:37 PM
What size bolts for soft top brackets? HoosierJeepster TJ Wrangler Technical Forum 3 06-07-2008 09:09 AM
