8.8 tech - JeepForum.com
post #1 of 5 Old 09-18-2005, 09:25 PM Thread Starter
Greencar
Greencar's Avatar
8.8 tech
Ok, I have an 8.8 that I am going to get regeared real soon. the current gears I beleive are 3.73's I am going up to 4.88's would I need a new carrier for this. Also, if I need it where can I get one online?
TIA
-Dan
Black 1994 YJ 2.5L
SOA
Greencar is offline
post #2 of 5 Old 09-18-2005, 11:02 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
you dont need a new carrier. i would suggest you do the locker now if you have any intention of getting one in the future.
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
post #3 of 5 Old 09-18-2005, 11:05 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
TIA
-Dan
there is no carrier break for the 8.8 so you should have no problem changing gears.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #4 of 5 Old 09-20-2005, 12:59 PM Thread Starter
Greencar
Greencar's Avatar
hey, thanks for the help guys. Now what about a notched cross pin? Do I need one that is a different size? Can I use the stock one and get away with it. I also heard that you can grind a tooth or two to get the stock one to fit. LMK
Thanks!!
-Dan
Black 1994 YJ 2.5L
SOA
Greencar is offline
post #5 of 5 Old 09-20-2005, 06:13 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
Thanks!!
-Dan
are you going to 4:88 gears?
if not, i dont believe you need either the notched pin nor to grind a tooth.
if you are, you can just take the tip off of one of the teeth to fit the pin. it doesnt take much, and is no where neer the contact pattern of the pinion.
many tech ?'s satchmoe YJ Wrangler Technical Forum 3 10-23-2009 07:46 PM
Would you do this?(Not Tech JF) TheBoogieman Wrangler General Discussion 11 04-30-2009 02:25 PM
This is not exactly tech gt4660 JK Wrangler Technical Forum 5 12-24-2007 06:56 AM
Need a little tech help. tautog27 TJ Wrangler Technical Forum 8 04-21-2006 01:35 PM
