8.8 swap kit? - JeepForum.com
post #1 of 11 Old 08-11-2011, 06:28 PM Thread Starter
Vin91
8.8 swap kit?
Ok so i have been looking for a 8.8 swap kit I'm going SUA and have already bought my axel... At one time i found a axel swap kit that came with everything i needed... Perches, bolts, drive shaft flange, solid diff cover and the brake lines an stuff for like 300 plus. Does any one have this kits or seen it online. i cant find it.....
Vin91 is offline
post #2 of 11 Old 08-11-2011, 07:03 PM
Nickabis
Yes, I bought a kit with everything plus more. This is where I got mine from.
http://www.knowwhere2jeep.com/know-w...angler-yj.html
Nickabis is offline
post #3 of 11 Old 08-11-2011, 07:36 PM Thread Starter
Vin91
That's it! How do you like that kit??
Vin91 is offline
post #4 of 11 Old 08-11-2011, 07:47 PM
I8AHUMR
I just installed that. I did sua with the Ubolt flip kit. I also used MORE's rear shock extensions with the shock tabs from the soa kit. Gets everything above the bottom of the axle.
93 YJ, 4.0, 4.5" suspension, 33x13.5 Pitbull Rockers, Custom scratch and dent job...
05 WK, 5.7 Hemi, Quadra-Drive II
I8AHUMR is offline
post #5 of 11 Old 08-11-2011, 08:00 PM
Nickabis
Thats exactly what I did, same exact thing. I am very happy with it and the guy there I spoke with is very helpful with any questions. I also bought the MORE front shock hoops a well.
Nickabis is offline
post #6 of 11 Old 08-11-2011, 10:08 PM Thread Starter
Vin91
What do the more shock hoops do?
Vin91 is offline
post #7 of 11 Old 08-11-2011, 10:10 PM Thread Starter
Vin91
Can you put the link up for the tabs from the more rear shock so i no which ones y'all used? That's seems like a great idea
Vin91 is offline
post #8 of 11 Old 08-11-2011, 10:10 PM
92 Green YJ
92 Green YJ's Avatar
You really could just get the perches and such cheaper individually. But more makes a full swap kit, as do a few other companies
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #9 of 11 Old 08-11-2011, 11:06 PM
Nickabis
Here is a link for the rear shocks. It relocates the top of the shock so you can have longer shocks or in my case, not have the bottom of the shock so far down on the axle. There is also a picture of the front shock hoops.
http://www.mountainoffroad.com/_e/Sh...87_95_YJ_s.htm
They are for the front shocks. I broke my shocks at the stud mount so I got those and put them on so I have the eyelet mount shock up top.
Nickabis is offline
post #10 of 11 Old 08-12-2011, 04:19 AM
I8AHUMR
The idea is to get everything up above the bottom of the axle. Look at your d35 and you'll see how the shock mounts tend to be down. Also Google 'Ford 8.8 in yj' and one of the first links will be a write-up from jedi.com. study it. It's for an soa but tons of good info on the swap. Look at his shock mounts vs what's in the kits.
I8AHUMR is offline
post #11 of 11 Old 08-12-2011, 04:24 AM
I8AHUMR
Also compare the soa vs sua pictures for the install kit. You should be able to tell a diff on the shock tabs.
I8AHUMR is offline
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
Rubi swap / Axle swap (merged) tjmike TJ Wrangler Technical Forum 5 06-10-2010 01:04 PM
body swap VS motor swap questions baltimorebiker YJ Wrangler Technical Forum 9 03-29-2010 09:49 PM
88 4 cyl swap transfer case swap to 89 6 cylinder ? YjShane YJ Wrangler Technical Forum 1 03-26-2010 04:11 PM
HVAC Control Swap: Swap just the lower ac/heater housing, or all of it? Justin Brimm TJ Wrangler Technical Forum 5 12-20-2007 03:29 AM
