8.8 Swap Done Cheap! - Page 3 - JeepForum.com
post #31 of 80 Old 10-10-2013, 03:26 PM
StanF
Originally Posted by Apollo12227 View Post
You don't have to buy a $400+ brand new CV style shaft. You can simply go to the junkyard and pick up a Cherokee XJ front driveshaft. Hop onto google, find a local driveline shop and go have the XJ front shaft shortened.
XJ front driveshaft is CV and can be used in the rear of the YJ, just needs to be shortened and balanced.
I have a writeup on using an XJ front DS as the rear of a YJ - in general, it's not something that I recommend. Check with your local shops first to confirm the shorten and balance price.
XJ Driveshaft in Rear YJ
StanF is offline
post #32 of 80 Old 10-10-2013, 03:39 PM
Apollo12227
Great writup btw!
Just currious why you wouldn't recommend it? I have one in my jeep with 36" tires and a detroit, havn't had an issue thus far. The OD of the shaft tubing its self is a little thin, i'll give you that, but other than that, what is the issue? Using a SYE // XJ shaft is certainly better than running as much lift as the OP has with NO SYE at all.
I ruined 3 stock YJ driveshafts before I got it through my head that you simply cant run a lifted jeep with such a short driveshaft on stock (slip in the tcase) equipment.
I have 2 XJ shafts cut down, using one full-time and the other is a spare.
Apollo12227 is offline
post #33 of 80 Old 10-10-2013, 04:54 PM
StanF
I just don't recommend it based on the costs involved - it may not save any money. I love the idea of reusing parts. It mainly depends on the cost of your local shop and the condition of the centering ball and u-joints.
StanF is offline
post #34 of 80 Old 10-10-2013, 04:59 PM
Apollo12227
Fair enough. Good info.
post #35 of 80 Old 10-10-2013, 04:59 PM Thread Starter
ashland82391
Originally Posted by johnboy68 View Post
Great write-up
Now that I have 33's I really need to do this. I have a D30 with 4:10 gears waiting in the garage to match the 8.8 I am getting.
Where did you get the shock mounts? How did you decide where to place them?
Any advice on setting up the brakes?
Thanks.
I reused the shock mounts. Just cut them off the d35. When I placed them I just knew they needed to be 2" inside from the perches and eye balled the rest. The turned out perfect.
ashland82391 is offline
post #36 of 80 Old 10-10-2013, 05:05 PM Thread Starter
ashland82391
Originally Posted by djwrangler View Post
According to the Tom Woods website (http://www.4xshaft.com/driveline101.asp), your driveshaft angle is set up for a CV shaft, not a stock shaft. The two ujoint angles are supposed to be equal or "phased".
I find it interesting that you have no vibs.
I don't know. I've been running this kind of pinion angle with the stock shaft for awhile and only had problems when I dropped my pinion back down. I ended up getting worse vibes, resulting in a pinion bating going out.
I'm sure the tom woods guys know what they are talking about but all I can say is this setup is working just fine for me so far. Although, I do plan on the sye in the future.
post #37 of 80 Old 10-10-2013, 08:21 PM
djwrangler
1997 XJ Cherokee
Im getting ready to do my 8.8 in a few weeks and was just pointing it out to you from the research I've done. I guess if it works for you, then run it. At least you're already set up for the SYE in the future
djwrangler is offline
post #38 of 80 Old 10-10-2013, 08:43 PM Thread Starter
ashland82391
yessir!
post #39 of 80 Old 10-11-2013, 04:56 PM
remmons
ubolts, center pins, spring perches, and spring plates
Those spring plates appear to be those that are used for a SOA conversion, due to their longer length to reduce axle-wrap. The SUA conversion perches are typically shorter so that they don't flatten out your springs. Did you cut them down or did you leave them full length?
Robert.
remmons is offline
post #40 of 80 Old 10-11-2013, 05:52 PM Thread Starter
ashland82391
Left them full length.
post #41 of 80 Old 10-11-2013, 05:53 PM Thread Starter
ashland82391
Update: drove the Jeep 120 miles hi way today with no problems.
post #42 of 80 Old 10-12-2013, 08:49 AM
coynea
None of the pics are loading for me... it just shows the photobucket logo
coynea is offline
post #43 of 80 Old 10-12-2013, 09:50 AM
bogleparsons
I used the same perches for my SUA 8.8 swap and didn't cut them, what could be the consequences?
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #44 of 80 Old 10-12-2013, 10:46 AM
jeepster93
jeepster93's Avatar
If you used SOA perches for an SUA application You will do a few things:
1 is to flatten out your springs.
Another and perhaps the biggest consequence is the loss of lift.
This is the flatten out part. If I were to tighten the ubolts here, the spring arch will be affected, flatten.
This is the loss of lift part. You can see how far the spring is from the axle. That is negative lift.
This is the modded perch. Do yourself a favor...get the right perch for the application. I didn't and spend a good effort modding the SOA perch for SUA.
jeepster93 is offline
post #45 of 80 Old 10-12-2013, 11:12 AM
kingcat400
I am also running soa perches sua and have no issues. They sat flat on the springs even before tightening the u bolts. I think it depends on the springs.
kingcat400 is offline
