8.8 Swap Done Cheap! - Page 2 - JeepForum.com
post #16 of 80 Old 10-08-2013, 07:10 AM Thread Starter
ashland82391
Originally Posted by Gage56 View Post
Wow How much did you get for the d35 ? ill be lucky if i can pull 150.00 for both d30 and d35
75$ from a friend that wanted the shafts and gears.
ashland82391 is offline
post #17 of 80 Old 10-08-2013, 07:26 AM
Robob69
Did you use the stock drive shaft as well?
Robob69 is offline
post #18 of 80 Old 10-08-2013, 07:29 AM Thread Starter
ashland82391
Yes sir
post #19 of 80 Old 10-08-2013, 07:49 AM
Gage56
Sigh,
If i could get my 30-35 sold i could get my 8.8 and 30 4.10 put in i even have the DC Shaft and SYE waiting for that time to come also
1992 YJ
Gage56 is offline
post #20 of 80 Old 10-08-2013, 08:10 PM
Robob69
I really want to do the SYE on my 231. I rebuilt it last year in the jeep and put a new OutPut shaft in it bc it was bent and causing a crazy vibration... I should have done it then but I did not have the crazy money it takes to get a CV drive shaft... I have to do one thing at a time but I know my D35 will hit the highway someday....
Robob69 is offline
post #21 of 80 Old 10-08-2013, 08:22 PM
jason280
How are the welds holding up on tube/pumpkin?
jason280 is offline
post #22 of 80 Old 10-08-2013, 09:01 PM Thread Starter
ashland82391
Good so far. Im sure I won't have any problems.
post #23 of 80 Old 10-09-2013, 04:38 PM
greenyj95
I would love to put an 8.8 in my yj eventually.
greenyj95 is offline
post #24 of 80 Old 10-09-2013, 04:47 PM Thread Starter
ashland82391
Good, it's a great upgrade.
post #25 of 80 Old 10-10-2013, 08:55 AM
johnboy68
HIP2BSQR
johnboy68's Avatar
Great write-up
Now that I have 33's I really need to do this. I have a D30 with 4:10 gears waiting in the garage to match the 8.8 I am getting.
Where did you get the shock mounts? How did you decide where to place them?
Any advice on setting up the brakes?
Thanks.
-John-
johnboy68 is online now
post #26 of 80 Old 10-10-2013, 09:49 AM
jokerchief462
Mines complete. I used a proportioning valve from a WJ. It only has two outlets you need three so for the rear lines I used a T.
I also did the double booster and a big master killer brakes.
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #27 of 80 Old 10-10-2013, 10:49 AM
bogleparsons
Originally Posted by johnboy68 View Post
Great write-up
Thanks.
I got my spring plates and shock mounts from RuffStuff, nice and Beefy
Also I raised my shock mount to where it doesn't hang below the axle tube anymore.
Now I need upper relocation brackets though
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #28 of 80 Old 10-10-2013, 11:58 AM
Apollo12227
I really want to do the SYE on my 231. I did not have the crazy money it takes to get a CV drive shaft... I have to do one thing at a time but I know my D35 will hit the highway someday....
You don't have to buy a $400+ brand new CV style shaft. You can simply go to the junkyard and pick up a Cherokee XJ front driveshaft. Hop onto google, find a local driveline shop and go have the XJ front shaft shortened.
XJ front driveshaft is CV and can be used in the rear of the YJ, just needs to be shortened and balanced.
Apollo12227 is offline
post #29 of 80 Old 10-10-2013, 12:29 PM
djwrangler
1997 XJ Cherokee
According to the Tom Woods website (http://www.4xshaft.com/driveline101.asp), your driveshaft angle is set up for a CV shaft, not a stock shaft. The two ujoint angles are supposed to be equal or "phased".
I find it interesting that you have no vibs.
djwrangler is offline
post #30 of 80 Old 10-10-2013, 12:34 PM
Apollo12227
This is true.
Standard non-sye setup calls for equal opposing angles. If your driveshaft comes off the tcase yoke down at 3* (for example) then your driveshaft would need to come off of the pinion at up 3*... The current setup may cause addtl strain to the pinion bearing and rear of the transfercase. I've seen a few bent stock output shafts, so be careful.
The correct setup w/SYE is to point the axle yoke directly at the tcase yoke, then drop 2-3* to allow for spring wrap.
