8.8 rear axle swap - JeepForum.com
post #1 of 9 Old 11-10-2006, 05:02 PM Thread Starter
redjeep669
2009 JK Wrangler
8.8 rear axle swap
have a few ?'s about the swap i didn't really get solid info on...
1 does it matter if you get the lsd or not? if i had a non lsd axle what would i need to add to it?
2 does it matter if the axle comes from v6/8, auto/manual, 2wd/4wd?
3 my jeep is non abs/drums and the 8.8 comes with abs/disc brakes. the brakes should function properly w/o the abs hooked up, right?
4 here's a descripton of one of the axles near me... '2SW4,AOT,4.10,NONLOC KING,BOLTED IN' what does KING and BOLTED IN refer to? i'm assuming AOT is auto od trans.
thanks for the help.
redjeep669 is offline
post #2 of 9 Old 11-10-2006, 05:15 PM
OhioYJ
I don't think it matters, if you get the open carrier you can always throw a lunch box locker in it. If it doesn't come with a LSD and you want one, you have to buy the LSD carrier, I typically see them on eBay for roughly $30. If you can't find one, I have at least one 31-spline 8.8 LSD laying around I'll sell you for that price.
All Explorer 8.8s are 31 spline. Not all Rangers are 31 spline. I'd stay away from Mustang 8.8s and Crown Vic 8.8s. Late 90s Explorer 8.8s are big bearing 8.8s, with the larger 7/8" cross shaft, and disc brakes, so these are ideal.
Yeah your brakes will be completely normal, its the ABS system and master cylinder that are different on ABS cars, the ABS axle is the same, just has a speed sensor on it. So don't worry about that.
Looks greek to me.
95 YJ: SOA, locked 44, locked 8.8, 37s, beadlocks, OBA, winch, and a few other things.
-- Mike
OhioYJ is offline
post #3 of 9 Old 11-10-2006, 05:22 PM Thread Starter
redjeep669
2009 JK Wrangler
thanks. a local yard has 4 96-00 non-lsd explorer axles all with disc brakes and 4.10's in good shape for 250. i might pick one up over the weekend.
post #4 of 9 Old 11-10-2006, 05:32 PM
yj-my-way
I agree 100% with ohio yj. My guess on ",NONLOC KING," is simply non-locking.
94 YJ 4.0/AX-15 - SYE & HD CV DRIVESHAFT
4.5 BDS - 2"BL - TJ FLARES - 8.8 4.10 DISC REAR
'02 WJ FRONT DUAL PISTON CALIPERS
K&N FIPK & BANKS HEADER & GIBSON CAT BACK
CUSTOM ROCKER GUARDS - WARN XD9000i WINCH
35 " GOODYEAR MT/R'S
yj-my-way is offline
post #5 of 9 Old 11-10-2006, 05:34 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
My friend Tim & I put together a good portion of 8.8 info in this thread you may want to check out.
http://www.jeepsunlimited.com/forums...d.php?t=674123
Here is a guide for the purchase and build-up of the Ford 8.8 rear axle and its compatability and performance in a Wrangler or Cherokee. [/SIZE]
I did a little scrounging around on Jeeps Unlimited and came up with some questions asked and answers given along with some of our experiences. Below there are many links to build-ups and all kinds of info.
If there are things i missed or mistakes please post a correction and i will change it or add more info to the first post.
There are many different variations of the Ford 8.8 axle. One of them is best suited for the use in a Jeep and that would be the Explorer (or Mountaineer) 31 spline 8.8. If you have found one off a Aerostar, Mustang, F-150 etc, you should really pass it up and look for a Explorer axle if you wish to retain a similar track width on your Wrangler. Trying to start your build-up with the wrong axle will be frustrating and expensive although you may have picked it up for cheap in the beginning.
Ford 8.8 assembly specs:
Cover bolt 28-38 ft.lbs.
Pinion bearing preload 16-29 in.lbs.
Pinion bearing preload 8-14 in.lbs (used)
Ring gear backlash .008-.015
Ring gear bolt to case 70-85 ft.lbs
Side bearing caps 70-85 ft.lbs.
Explorer 8.8 Measurements:
Weight (complete assembly w/ brakes etc.): 174 lb.
O.D. of tubes: 3.250".
Tube thickness: .250" (some are .188”!)
Ring gear diameter: 8.800".
Ring gear bolts: 7/16" dia. (qty. 10).
Pinion diameter/splines: 1.625 / 30.
Axle shaft/splines: 1.320 / 31.
Rotor thickness (where it mounts to axle is .250").
Overall width 59.625" (the F8.8 is .950" narrower then a TJ Dana 35).
(The F-150 8.8 is drum brake and width WMS to WMS is 65.5”.)
Hole diameter for ABS sensor in top of housing: .811".
Bolt size (U-joint flange to yoke) is: 12 x 1.75 x 30 mm
Centerline of housing to C/L of pinion difference is 3.875" toward the P/S.
Pinion offset: P/S to C/L of Pinion, 27-3/4" (no rotor on axle), D/S to C/L of Pinion, 31-5/8" (no rotor on axle). (this measurement is 2.5" more offset to the P/S then a TJ Dana 35).
Specs:
Code Capacity Ratio
43 Open 3200 3.08
41 Open 3200 3.27
42 Open 4.10
46 Open 3.73
45 Open 3200 3.55
D4 Limited Slip 3200 3.73
D2 Limited Slip 4.10
L73 Limited Slip 3.73
L - Limited Slip Differential
C - Conventional Differential
Thanks Chris Overacker for the specs and measurements! see his website link below.
How many splines are the axle shafts?
drivers side is 31 spline for 97 & up Mountaineer, 95 & up Explorer, 30-1/2 inch length - 5 X 4.5 inch lug pattern.
passenger side is 31 spline for 97 & up Mountaineer, 95 & up Explorer, 27-5/8 inch length - 5 X 4.5 inch lug pattern
Can I get 35 spline shafts? Yes, with a little searching I found 28 and 33 splines too. Remeber 8.8 axles are used on many different Ford rigs. Mustangs, Rangers, F150s, Aerostar etc... different axle lengths than the Explorer so if you are looking for aftermarket products make sure you are not looking at something for a Mustang that might not fit an Explorer. For the 35 spline stuff check with Mark Williams site. i dont have a link yet but i will soon.
Do I need a slip yoke eliminator? In my opinion, yes
Can I use my drive shaft that I bought for my SYE/Dana 35 set-up? Yes
Is the 8.8 narrower than a Dana 35? Yes but not enough to make a difference when running most aftermarket wheels.1.5" shorter or so. It doesn't matter unless you try running stock rims w/12.5 or wider tires.
Are the 8.8 shafts stronger than Dana 44 shafts? Yes, also the bearings, pinion and ring gear are also much larger.
Axle shaft Strength and output torque rating by Warn and 4 Wheeler
The axle shaft strength tested by Warn Ind:
F8.8= 6,500 (lb. ft.)
D44= 4,600-5,000 (lb. ft.)
D35C= 4,000-4,300 (lb. ft.)
COT: Continuous output torque rating
MOT: Maximum output torque rating
(Numbers from January edition of Fourwheeler, page 60.)
Dana 35 rear axle COT: 870 MOT: 3480
Dana 44 rear axle COT: 1100 MOT: 4460
Ford 8.8 28spline COT: 1250 MOT: 4600
Ford 8.8 31spline COT: 1360 MOT: 5100
Dana60 semifloat COT: 1500 MOT: 5500]
(thanks joe and Chile99.)
Will I need that brake proportioning valve from a Rubicon? Maybe
Does the 8.8 offer more ground clearance over the Dana 35 and 44? Not under the differential but the bigger axle tubes lift the rig about 5/8 ".
Is there welding involved? Yes, but the new brackets you put on are much stronger than stock Dana’s. Not a good idea to re use your old Dana 35 brackets
Where do I get brackets?
4x4 Group Buy has Rubicon Express for $225+shipping.
Bob Supplee has Tera for $220 shipped.
DC4WD has Tera for $217 shipped. thanks jamie 9/21/05
Jeepers and Creepers
TeraFlex TMI-ABK-TR $250.99
M.O.R.E. Dana 35 brackets (sku:MORE98700)
Rubicon Express RE9969 TJ Axle Bracket Kit Rear
Mad4wd.com (sku:Mad-BKTK-TJ1)
Link to axle bracket placement on Stu Olson's site
The list above should get you headed in the right direction as far as brackets go. Look around and compare prices as the brackets can be found for $200.00 or less shipped sometimes. Keep this in mind when shopping for any item for your build-up,if you do, you will save a bundle.
Can I reuse my Dana 35 brackets? Yes, but it is not recomended. The stock Dana 35 brackets are sort of flimsy compared to the beefy aftermarket versions. Some of the brackets available are in fact for Dana 35 axles to replace the weak ones that come factory. Reusing the D-35 brackets is time consuming even if you have the right tools, not a good idea IMO
Should I weld the axle tubes to the cast housing? I would if it had been salvaged from a wrecked rig. If it is new on a crate (in my opinion) don’t bother.
(picture of joe dillard's axle tube welds below.)
Will my stock sway bar work? Yes, with a minor modification to a passenger side pinion gusset.
Do all 8.8s come with a limited slip? No, read the tag on the housing or remove the cover. 3L73 = 3.73 gears witha "L"imited slip
Where is the gear break for lockers? There is no break. Same locker for 3.73 to 6.14
Do I need a notched cross pin? Yes for 4.56-6.14 to clear ring gear, or notch a gear tooth.
More cross pin info from NovaTJ:
The 3/4 inch cross pin only fits those rears with the 28 spline count period!
Therefore, the 7/8 inch crosspin is what we are concerned with and it fits Explorer, Mountaineer, F150, and Expedition's with the 8.8 ring gear and 31 spline axles. It also come in those special Mustangs that have the 31 spline axles i.e. Cobra, Steeda, and Rousch.
The axles for Jeep conversion we are keen on are the 96 through 2001 Ford Explorer and Mercury Mountaineer with disc brakes and all that fall into this category with or without limited slip have the 7/8 inch cross pin.
What year ford explorers do I look for as a donor for 31 spline and disc brakes? 1995 to 2001.
What is so great about 8.8? Parts are everywhere, as in axle shafts, covers, brake parts etc..
What's not so great about the 8.8? Weak stock carrier, replace with a carrier type locker like ARB or Detroit (not a lunch box type) this will cure the problem.
Spun axle tubes: Simply weld the tubes into the diff housing before they spin. You are welding to cast steel so now would be the time to ask for a professional's opinion. I have heard of guys tossing the works in a oven before welding, some just go at it cold. Both say their way is right.
Thin stock diff cover: Get some armor.
(my axle was new surplus and had not been in a collision, i know exactly where it has been from mile one and it is not welded. I dont believe my wheeling style will cause me problems, however i do keep a close eye on the plug welds.)
What kind of locker can I get? Thanks Joe
ARB SELECTABLE AIR LOCKER
AUBURN GEAR - ECTED ELECTRIC LOCKER
AUBURN GEAR - HIGH PERFORMANCE LIMITED-SLIP DIFFERENTIAL
AUBURN GEAR - PRO SERIES LIMITED-SLIP DIFFERENTIAL
DETROIT LOCKER
E-Z LOCKER - FITS IN FACTORY NON-POSI CASE
EATON - ELOCKER SELECTABLE LOCKING DIFFERENTIAL
EATON - POSI LIMITED-SLIP DIFFERENTIAL
FULL SPOOL - 31 SPLINE - STEEL
MINI SPOOL - 31 SPLINE - C-CLIP COMPATIBLE - STEEL
ORIGINAL STYLE POSI - COMPLETE
POWERTRAX - LOCK-RIGHT LOCKER - FITS IN FACTORY NON-POSI CASE
TRUTRAC LIMITED-SLIP
Joe Dillard is offline
post #6 of 9 Old 11-10-2006, 05:39 PM
Joe Dillard
Continued:
What is the bolt pattern? 5 on 4.5” just like stock TJ/YJ wheels.
Will my Jeep lug nuts fit the 8.8? In most cases, yes.
What do I do with the speed sensor? leave it in place.
Where to buy?
Car-part.com
www.ok4wd.com
wallysheata, Ariel Performance
www.alljeep.com
http://www.rockequipment.com
to name a few.
How much do they cost? Free to $1500.00 but you can find them new for around $500.00 in their stock form complete disc to disc.
What do I need for a swap into a tj?
Here are some things I used:
-TeraFlex Bracket kit
-ARB
-U.S. Gears 4.56
-Master install kit (Timken)
-Crane diff cover
-Napa brake line kit P/N 380528 (x2)
-T-hose NAPA P/N 380889
-ZJ E-brake cables (drivers and passenger side)
Mopar P/N 52008904 & 52008905 NAPA P/N 95533 (right) 95322 (left). (not for YJs)
-Driveshaft adapter: Spicer 2-2-1379
-Flange bolts Ford P/N N800594-S100 (x4)
-'03 TJ Rubicon (w/disc) proportioning valve P/N 5083808AA
-3/16" hard brake line about 40" & 18"
HELPFUL SITES be sure to check these out:
Stu-Offroad
Dome & Detour
8.8 Swap
J.E. Towle / DPG Offroad
Chris Overacker / CODE 4x4
Stormtrooper
4x4 Wire Links
The Ranger Station Tech Library
The Ranger Station Tech Library 2
YJ & XJ STUFF:
From M.O.R.E.
-XJ Installation Kit P/N 98600 84-2001 XJ
-XJ E-Brake Cable Kit P/N EB3 Disc Brake F8.8 Only
-Special Yoke P/N 221379 F8.8 to 1310 U-Joint
From Dealership:
-Mopar spring perches
-Tabs for shock mounts
-ZJ ebrake cables from the dealer (for XJ install)
-Flange from spicer dealer $30 (have seen this go from $20-$50)
:wb:A BIG THANKS TO ALL THOSE WHO PARTICIPATED IN THIS THREAD!!! (whether they knew it or not):wb:
BENT SHAFT????
Joe Dillard's 8.8 Shaft Replacement Thread
Joe Dillard's Super 88 write-up!
Check out T.Dome's SUPER 88 Write-up on Stu's site!
Here is a 8.8 DISC BRAKE HOW-TO from Autozone's website. clicky-clicky... :shades:
8.8 PART NUMBERS:
Rear Caliper Bolts p/n N606046-S60 List $4.10 each (9/06)
Flange bolts P/N N800594-S100 $1.29 (x4) (5/05)
If you have some Ford part numbers you want to ad just pm me.
This may help you find something in our discussions a little easier. It is not as perfect as I imagined but it is what you got. It should be mostly right. this will take you up to page 44
8.8 Index:
5/8” lift: 11, 12
  • 8.8 difference, v6 vs. v8: 7, 10
  • ABS: 15, 18, 44
  • Additives: 29, 30
  • Armor: 27, 28, 33
  • Axle shaft lengths: 2, 43
  • Bearings: 44
  • Belly-up: 22
  • Bent axle shaft: 18-20, 23, 40
  • Bent output shaft: 19
  • Bolt patterns: 7
  • Brackets: 2, 3, 8-10, 12-16, 20-24, 26, 35, 38-40, 42
  • Brakes: 4, 7, 8, 16-18, 23, 27, 28, 30, 31, 33, 38-42
  • Caliper and brake r&r: 6
  • Capacities: 30
  • Carrier break: 6, 7, 10, 23
  • Control arm length: 8
  • Cross pin: 2, 13, 21, 26-29
  • Drive shaft: 3, 14, 29, 34, 35
  • Droop: 28
  • E brake: 14, 21, 27, 29, 31, 34
  • Flange adapter: 3-5, 8, 12, 17, 23, 24, 32, 33, 35-37, 40, 41
  • Gas tank clearance: 11, 35-37
  • Gear lube: 6
  • Gear pattern: 13
  • Gear ratios: 7
  • Helpful hints: 34, 42
  • Installs / updated installs: 18, 19, 34, 36, 37
  • Leaking seals: 6
  • Locker: 19-21, 24, 29, 42, 43
  • Lug nuts: 6
  • Part numbers: 7
  • Pinion angle: 27, 29, 40
  • Proportioning valve: 14,15,16,33
  • Shaft upgrades: 7, 9, 19, 20, 24
  • Shaving: 11, 38, 43, 44
  • Shock clearance: 7, 25
  • Skids: 11
  • Speed sensor: 9
  • Strength comparison: 3, 10, 14, 36
  • Stock brackets: 9
  • Stock brake part discussion: 5
  • Stock carrier: 10
  • Super 88: 37, 38, 42, 43, 44
  • Sway bars: 8, 15, 19, 37
  • SYE: 3, 11, 13
  • Tag translation: 2, 41
  • Tire size: 22
  • Tone ring: 27, 28
  • Truss: 19, 22, 44
  • Upside down calipers: 31
  • U-joint: 21, 25
  • Welding tubes: 3, 4
  • Where to purchase? 11
  • Wheel spacers: 37
  • Wheel vs. caliper: 4, 34
  • Why an 8.8? 22
  • Vent: 17, 26, 30, 36
  • Vibes: 7, 11
  • XJ/YJ parts: 5, 21
post #7 of 9 Old 11-10-2006, 06:28 PM Thread Starter
redjeep669
2009 JK Wrangler
thanks!
would it be best to wait until i did the soa conversion to swap the 8.8 in?
post #8 of 9 Old 11-10-2006, 07:08 PM
Joe Dillard
That's the approach I took. I wasn't about to sink another dime into my old D35C rear axle.
post #9 of 9 Old 05-07-2010, 01:05 PM
hardcoreskimmer
i didnt see ox locker on that list
99 TJ 4 banger 2.5" skyjacker 31" buckshots
hardcoreskimmer is offline
How to do a rear axle swap. Benderff TJ Wrangler Technical Forum 40 12-02-2012 04:53 PM
89 XJ rear axle swap into 95 YJ? eatsleepjaydiem YJ Wrangler Technical Forum 4 05-03-2010 05:02 AM
Rear Axle Swap 44 or 9 in? cvogt26 TJ Wrangler Technical Forum 18 08-28-2009 06:33 PM
rear axle swap lkg351 YJ Wrangler Technical Forum 6 02-24-2009 03:56 PM
Rear Axle Swap JSBlu974X4 TJ Wrangler Technical Forum 5 04-05-2004 09:02 AM
